Hi i am having problem on Dell 3521 is giving 7 beeps and no +VCC_CORE and +VCC_GFX_CORE_AXG. Did anyone having same experience. I found a video it says to correct 7 beeps to flash ec controller. Is it will help me ? actually i don't have ec programmer. i have only TL866cs.
					Dell 3521 with 7 Beeps
 Re: Dell 3521 with 7 Beeps
 flash the two bios one is near pch 25q16 and other side have 25q32 flashComment
 Once I have solved 7 beeps with just heating cpu, reball is not necesary.Comment
 I reflow to CPU and PCH Nothing changed. Also I flashed both bios 25q16 and 25q32 but no use. i try to inject +VCC_CORE by +0.91V its not shorted. So i thing the cpu not shorted. Now i have only one think to do it, that is reprogram the io chip ( KB1902 )Comment
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			by jasonbay13it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
 PU200
 pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
 pin 8 vreg3 = 0v
 pin 13 en = .2v
 pin 1,6 entrip1,2 = 0v
 b+ and b++ = 19.5v
 +5valw = 0v & 25+ohm to ground
 +3valwp = 0v & 25+ohm to ground
 i cleaned the board up just a little and can get more pics.
 where should i be looking? thx...
			by doctormasryhellolaptop dell 3521 la-9104p no light on screen
 i can see data ok but no backlight
 on jlvds
 NV_PWR_SRC 18 v is ok
 3vs is ok 3.3
 lcdvdd is ok 3.3
 i replacd led screen
 and change flata ( caple between board and led )
 any idea...
			by cygronModel: Dell Latitude 3440
 Board id: DL340-HSW MB 13221-1 Rev: A00
 Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
 PL4503 - 3.3V
 PL4101 - 5V
 PL4902 - 1.35V
 PL4801 - 1V
 PL4701 - 1.7V
 PL4401 - 17V
 PL5101 - 0V
 PU5102 pins -
 Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
 Pin 2, 4 - 0V
 Pin 3 - 0.95V
 Pin 5 - 2.87V
 Pin 6 -...
			by jeewanthaMotherboard - VAW00 LA-9104P
 Rev:1.0(A00)
 Board power on with 7 beeps
 No Display
 I checked All voltages
 +VCC_CORE not present.
 I changed PU700, Reprogram Bios but still same.
 Anyone can give help to repair this.
- Loading...
