Dell 3521 with 7 Beeps
    Hi i am having problem on Dell 3521 is giving 7 beeps and no +VCC_CORE and +VCC_GFX_CORE_AXG. Did anyone having same experience. I found a video it says to correct 7 beeps to flash ec controller. Is it will help me ? actually i don't have ec programmer. i have only TL866cs.
    Re: Dell 3521 with 7 Beeps
    i replaced PU700 ISL95833HRTZ-T chip also. nothing changed.
      I think either the onboard processor has failed or PCH failure.
        Reball the processor. If no change will be happened, then replace it. Your problem will be solved.
          flash the two bios one is near pch 25q16 and other side have 25q32 flash
            Thanks for supporting. I already done to both bios. its not helped. i don't know those dumps were working or not. Can you send it to me
              Once I have solved 7 beeps with just heating cpu, reball is not necesary.
              Original Dell parts for sale
                I reflow to CPU and PCH Nothing changed. Also I flashed both bios 25q16 and 25q32 but no use. i try to inject +VCC_CORE by +0.91V its not shorted. So i thing the cpu not shorted. Now i have only one think to do it, that is reprogram the io chip ( KB1902 )
