Dell 3521 with 7 Beeps
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Hi i am having problem on Dell 3521 is giving 7 beeps and no +VCC_CORE and +VCC_GFX_CORE_AXG. Did anyone having same experience. I found a video it says to correct 7 beeps to flash ec controller. Is it will help me ? actually i don't have ec programmer. i have only TL866cs.
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Dell 3521 with 7 Beeps
    i replaced PU700 ISL95833HRTZ-T chip also. nothing changed.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I think either the onboard processor has failed or PCH failure.
      • subroto
        • Oct 2015
        • 230
        • Bangladesh
        Reball the processor. If no change will be happened, then replace it. Your problem will be solved.
        • naeemshahzad
          • Jan 2015
          • 129
          • uae
          flash the two bios one is near pch 25q16 and other side have 25q32 flash
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Thanks for supporting. I already done to both bios. its not helped. i don't know those dumps were working or not. Can you send it to me
            • lvalius
              • Jan 2017
              • 35
              • Lithuania
              Once I have solved 7 beeps with just heating cpu, reball is not necesary.
              Original Dell parts for sale
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                I reflow to CPU and PCH Nothing changed. Also I flashed both bios 25q16 and 25q32 but no use. i try to inject +VCC_CORE by +0.91V its not shorted. So i thing the cpu not shorted. Now i have only one think to do it, that is reprogram the io chip ( KB1902 )
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • cygron
                  Dell Latitude 3440 2 Beeps Problem
                  by cygron
                  Model: Dell Latitude 3440
                  Board id: DL340-HSW MB 13221-1 Rev: A00
                  Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
                  PL4503 - 3.3V
                  PL4101 - 5V
                  PL4902 - 1.35V
                  PL4801 - 1V
                  PL4701 - 1.7V
                  PL4401 - 17V
                  PL5101 - 0V
                  PU5102 pins -
                  Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
                  Pin 2, 4 - 0V
                  Pin 3 - 0.95V
                  Pin 5 - 2.87V
                  Pin 6 -...
                  04-20-2025, 03:46 AM
                • jeewantha
                  Dell Inspiron 3521 7 Beeps
                  by jeewantha
                  Motherboard - VAW00 LA-9104P
                  Rev:1.0(A00)
                  Board power on with 7 beeps
                  No Display
                  I checked All voltages
                  +VCC_CORE not present.
                  I changed PU700, Reprogram Bios but still same.
                  Anyone can give help to repair this.
                  02-12-2022, 03:05 AM
                  Dell Inspiron 3521 15" Laptop Schematic & Board View
                  Dell Inspiron 3521 15" Laptop Schematic & Board View...
                  10-03-2024, 12:54 PM
                • tech_guru
                  Dell Inspiron 5558 8 Beeps
                  by tech_guru
                  Hello.
                  If you can help with this one please...The laptop does 8 beeps at boot which as I see is LCD error. The laptop shows image to external monitor normally. New screen flex and screen does not change anything.
                  So I took measurements in the LCD socket (LCD1):
                  DCBATOUT_LCD 19V
                  LCDVDD_LCD 3.3V
                  DBC_EN_R 0V
                  EDP_HPD_CONN 3.2V
                  LCD_TST_C 0V
                  EDP_AUX 3V
                  EDP_AUX# 0V
                  EDP_TX0# 0V
                  EDP_TX0 0V
                  EDP_TX1# 0V
                  EDP_TX1 0V
                  LCD_BRIGHTNESS 0V
                  BLON_OUT_C 0V
                  PANEL_SIZE_ID_CONN 0V​
                  The ones that are 0v,...
                  02-18-2025, 02:13 AM
