dead macbook 820-2936-B
  • ukRich
    • Dec 2016
    Need help with diagnosing this problem
    820-2936 no power,magsafe green, fan spins for a second then stops then repeats. Board is liquid damaged and when I got it I was not getting any ppv5_s5. Replaced u7200 and c7273 that was shorted
    All rails ok until I get to pp5v_s3. if I watch the MM, it jumps to 5v then straight to 0v. In diode mode does not show any short to ground but Im obviosly missing something
  • vinifera
    Vinifera
    • Aug 2018
    • 28
    • Belgium
    Re: dead macbook 820-2936-B
    i have the same problem ? What did you find ? PP5V_S3 go on and off
    • piernov
      • Jan 2016
      • 4437
      • France
      Liquid damage? History of the board?
      Green light on Magsafe? Fan spinning?
      ALL_SYS_PWRGD and CPU VCore present?
      Almost every board issue is different so you have to give the most information possible to be able to troubleshoot it properly.
      • vinifera
        Vinifera
        • Aug 2018
        • 28
        • Belgium
        after reflow the gpu, the fans goes on and off for 1 seconde.
        After check of the power lines ; PP5V_S3 and PP5V_S0 ;
        PP5V_S3 0-5-0-5-0V 5V "ON/OFF
        short check = 0,422 as a good board"
        PP5V_S0 0-5-0-5-0V 5V "ON/OFF and goes to 5V and 0,18V
        short check = 0,395 = as a good board"
        green light on magsafe and orange when connecting a battery
        This problem is occured after reflow the GPU, because before it works.
        I think of a current sense problem ? but where to look further ?
        • vinifera
          Vinifera
          • Aug 2018
          • 28
          • Belgium
          I have done a reflow , because the boot line doesn't go further. I think that i damaged something , but which further steps to find ?
          • vinifera
            Vinifera
            • Aug 2018
            • 28
            • Belgium
            Which current sense problem ?
            • piernov
              • Jan 2016
              • 4437
              • France
              Cannot help you if a GPU that doesn't even exist was randomly reflowed for no reason, sorry.
              • jesi
                macbook pro a1707 dead
                by jesi
                hi all techs
                require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                update:
                when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                08-24-2025, 04:34 AM
              • robka
                MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                by robka
                my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                After that the Macbook was dead. It isn't charging anymore.
                The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                03-02-2024, 02:58 PM
              • Rav_tangle
                MacBook Pro 2011 turns on with keyboard light , screen dead
                by Rav_tangle
                Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                is this...
                05-31-2024, 04:09 PM
              • yuuki47
                A2681 M2 MacBook Air Dead Logic Board
                by yuuki47
                Hello...
                My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
                We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
                eBay replacements run about £367 with the Touch ID sensor included.
                I did consider to probe the logic board for shorts...
                04-13-2024, 06:22 AM
              • envym
                MacBook Pro 2018 with Activation Lock
                by envym
                Hi everyone!
                I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                06-27-2025, 08:54 AM
