L300 v000138370 6050a2170401-mb-a03 ...
    Hi and happy new year for all
    i have this laptop:
    L300 V000138370 6050A2170401-MB-A03 ...toshiba l300
    the problem is vga flickering lines
    i did bios update and changed nec/tokin capacitor with no success
    the vga is intel
    what can i do??
    thnx
    Re: L300 v000138370 6050a2170401-mb-a03 ...
    First, check the video cable that may be loose or broken.
    Do you mean "vga flickering lines" to be the fault only on external monitor?
      the problem is in both internal and external monitors, in safe mode there is no problem
        So the problem seems to be in the graphics driver.
        Try another version of OS.
          Ok. Usually if that intel chipset sharing Ram as the Video memory. So try to check with another RAM or check the RAM SLOT for Corrosion or dirt on pins. I think this will help.
            i already changed the ram and cleaned the ram slot with no success
              the problem is with high resolution only
                no the problem without driver
                  Need reballing on chipset.
                    Try to boot with a live CD as Linux and see if you have the same problem.If yes it is the VGA if not it's the software driver.
                      Could you up load pictures with the fault it will help thanks
