Lenovo G50-45 constant reboot
  • Scootie
    • Feb 2014
    • 133
    • Romania
    So I have this laptop that for no reason reboots when loads the OS. However, it stays on if I leave it in bios. I tried 3 different rams while running 3 different versions of memtest(many reboots) and came to the conclusion that it cannot be the rams nor cpu overheating cause I cleaned the fan(which was clean anyway).
    The board is an NM-A281 and it went out of warrant like weeks ago.
    I measured what I could on the board and everything seems to be okay.
    Dont want to risk to update bios in fear of reboot.
    Anyone familiar with thie behavior and this laptop model?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Lenovo G50-45 constant reboot
    This seems a classic problem since Windows 98.
    It may be the graphics chip.
    had you updated the graphics driver before this problem happened?
    had you installed a new OS before this problem happened?
    • Scootie
      • Feb 2014
      • 133
      • Romania
      The laptop reboots simply by running the memtest.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Load the OS in safe mode and check what error message it gives.
        • Scootie
          • Feb 2014
          • 133
          • Romania
          Actually I dont even get BSOD. Will have to check tomorrow if its set to automaticly reboot on such event. Will be back.
          • Scootie
            • Feb 2014
            • 133
            • Romania
            I disabled the option to reboot automaticly if something occured but even so no BSOD, just plain reboot.
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              Load the OS in safe mode and tell us at which stage of the OS loading, it reboots.
              • Scootie
                • Feb 2014
                • 133
                • Romania
                Loaded the OS, it stayed on until I shut it down.
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  So, the laptop has no reboot in safe mode.
                  Thus, a hardware or software component causes the reboot which is not loaded in the safe mode.
                  • Scootie
                    • Feb 2014
                    • 133
                    • Romania
                    Looks like it reboots while in safe mode too.
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      So this gets more difficult.
                      there is a CD in the Internet called Ultimate Boot CD.
                      Boot the laptop using this CD and test different parts of the laptop using the software tools in this CD.
                      Then, you may find the part of the laptop that causes rebooting.
                      • jiroy
                        • Jun 2016
                        • 2416
                        • Lebanon
                        Graphic cards error symptoms appear after one year and a half at least and rarely before that , so it Could be CPU heating from a dirty fan , or a virus like Catharina or any other malware . A wrongly updated driver can do this too , as well as resetting Rams .
                        I would start anyway by re-installing the system .
                        • Scootie
                          • Feb 2014
                          • 133
                          • Romania
                          The system reboots while running simple memtest otherwise I would have reinstaled the OS. The laptop doesnt have dedicated vga, only what the CPU provides.
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            I assume you tried also to remove a probable defective battery , tried booting a linux ? , if so then the Bios is next ..
                            • medi777
                              • Sep 2013
                              • 18
                              • Albania
                              have you tested the hdd?
                              • Scootie
                                • Feb 2014
                                • 133
                                • Romania
                                I've run the memtest with removed harddrive and got many reboots.
                                • jiroy
                                  • Jun 2016
                                  • 2416
                                  • Lebanon
                                  Did this laptop by any chance , had a strong blow or was dropped ? , I had one or two strange cases like this , and it turn out the Bios battery was detached from one solder point , in the second one , i had to resolder the battery , which fixed also some random errors behaviour .
                                  • Scootie
                                    • Feb 2014
                                    • 133
                                    • Romania
                                    By the looks of it nothing of the sort has happened but I will ask the client.
                                    • x_orange90_x
                                      Samsung UN50KU6300F constant reboot, bad backlights?
                                      by x_orange90_x
                                      This TV is in a constant reboot where the screen very dimly lights up for about 2 seconds and says SMART TV. I checked the power supply and visually all components look good. I unplugged the main board to see if the backlights would come on but they do not. I also tried my LED tester on the backlight plug and didn't get anything. I know some Samsungs will not light off a single led is out regardless of using a tester, so I'm thinking they are bad. I found a whole set for about $25 which isn't bad, but before I buy them is like to know if they would indeed cause a constant reboot like this tv is...
                                      02-09-2024, 08:41 PM
                                      Lenovo 3000 Series Schematic
                                      Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                      3000 C100 laptop with Braille keyboard
                                      Lenovo 3000 C
                                      C100, C200 - 15-inch XGA screen
                                      Lenovo 3000 N
                                      N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                      N500 - 15.4 inch screen.
                                      Lenovo 3000 V
                                      V100, V200 - 12.1-inch WXGA models
                                      Lenovo 3000 G
                                      G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                      10-04-2024, 06:05 AM
                                      Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                      09-06-2024, 06:40 AM
                                      This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                      09-06-2024, 06:06 AM
                                    • derradji89
                                      Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                      by derradji89
                                      Hi everyone 🤗
                                      I have a Lenovo MIX 320-10lCR computer.**
                                      1. **Operating System**: Windows 10 ** Education** 64-bit.
                                      2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                      3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                      4. **BIOS Chip Reflashing**: Currently,...
                                      04-19-2025, 03:04 PM
