HP no power (chip level) help!!
  • atiqfajar
    • Oct 2016
    • 10
    • Malaysia
    my laptop hp-cq41 has stopped working recently so i've try alot of solution but it seems like not to work...
    symptoms : - split second light
    - no power
    i have attached some image that might help to find the problem
    on number 1 box, on s0 state, it is quite hot but other component like cpu, gpu and bridge seems not working
    on number 5 box, there is some voltage drop at the output pin... from 3v to some 1v-ish
    Any solution is welcomed
    TY for your time... help me find the problem
  • mielta
    • Apr 2015
    • 368
    Re: HP no power (chip level) help!!
    Hello
    i send you the schematic
    • dreamer_x_x
      Ottoman Empire
      • Nov 2016
      • 18
      • turkey
      hi bro,
      is your motherboard ground with PL (coils) measure short circuit ? check it.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        So using the supplied info from mielta I would check and verify the modifications are correct and up to date. On the modifications I would be looking with what is failing. So too verify: in the So State you have all the voltages on page 3?
        • atiqfajar
          • Oct 2016
          • 10
          • Malaysia
          Thanks @mielta.. but i don't quite know how to use the schematic... Because this is my first time attempting fix at chip level
          @dreamer_x_x the coil near the overheating chip is around 1600++ ohm.. so i assume no short.. thanks
          • atiqfajar
            • Oct 2016
            • 10
            • Malaysia
            @keeney i couldn't tell which is B+ or anything because in the schematic, there is no guide like the pq102 or pu etc... Thanks
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              [QUOTE=atiqfajar;705966]@keeney i couldn't tell which is B+ or anything because in the schematic, there is no guide like the pq102 or pu etc... Thanks[/QUOTE
              Yes there is on page 43. Once you save the PDF schematics go to edit. Click on edit. Look down to the word find. Click on find. Now a pop up on the right side will appear. Put in pq102. Then press the button enter.
              Now if you want to find B+ do same above procedure but insert the B+ where you but the pq102. It will find B+ and when you press enter again it will find the next B+ on the schematics and so on. This works with most schematics however it is dependant on who made the PDF.
              • atiqfajar
                • Oct 2016
                • 10
                • Malaysia
                Sorry for late reply, the PU301 is overheating and the voltage reads at each pin at s0(off) are :
                (v)
                1 1.2
                2 no reading (0.019)
                3 2.1
                4 2.1
                5 0.3
                6 1.1
                7 3.5
                8 3.5
                9 8.5
                10 3.3
                11 3.3
                12 0
                13 3.1
                14 2.1
                15 0(ground)
                16 12
                17 5.3
                18 5.3
                19 0
                20 5.3
                21 5.1
                22 10
                23 0
                24 5.3
                Tell me if anything is wrong with the readings
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • eukal
                  Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                  by eukal
                  Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                  I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                  I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                  I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                  07-01-2023, 01:00 PM
