Its power coming to 19V, 5V, 3.3V are ok When i press power switch power comes fan working and its off again within 2 Seconds. But it shows 19v, 5v, 3.3v. anyone having same problem or anyone who solved this same. on PCH area only shows power when its on stage but its goes after 2 seconds.
					HP DV6 DALX6HMB6C0 Power
			by PantherDaveHi all!
			by GLISITHi all,
			by liquidzorchHello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
			by Mita99Hi,
 Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
 Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
 Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
- Loading...
