Toshiba C875-S7205 power on but no screen
  • Naturallyk2
    • Nov 2014
    • 64
    Hello everyone. Here is the issue I have. I have a Toshiba C875 that will turn on, but the screen will not come on. Zero display. I've swapped out the ram with no success. I've ordered a new MB with no success. I've changed the processor with no success. I've unplugged everything from the MB except power input, power button, and display connection with no success. I've plugged it into a monitor via VGA cable with no success. What else could I possibly do to troubleshoot this?!
  • dreamer_x_x
    Ottoman Empire
    • Nov 2016
    • 18
    • turkey
    Re: Toshiba C875-S7205 power on but no screen
    GPu's crystal oscillator check or gpu rework ball
    • Melamanti
      • Nov 2015
      • 17
      • Greece
      That motherboard is faulty as hell! Even if you do reball the gpu chances are you are going to need to replace the chipset itself as it will make no difference.
      Trust me i had to throw a lot of them in the pile of scraps.
      Have you tried resetting the bios?
      • daniel6699
        • Sep 2018
        • ireland
        I need tosiba c875-13l BIOS
        PLF/PLR/CSF/CSR DSC MB REV: 2.1
        RAW Rom somebody got it?thanks
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • grimacelord
          HP 15-EH1070wm - Black Screen With Power LED.
          by grimacelord
          I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
          First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
          01-28-2023, 10:50 AM
        • joaquinmjuan
          Canon TS8350 Screen Freezes on Power On
          by joaquinmjuan
          Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
          05-07-2025, 12:26 AM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
          03-31-2024, 02:12 PM
