hp G62 DA0AX1MB6H1 REV:H confusing problem.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello everyone.
    i got this hpg62 with strange problem.
    it works perfect when its connected to his charger with the battery on it.
    but when you disconnect the charger with battery alone it goes very slow to response everything. i notice when i playing games
    and when i put it back the charger and it goes back to smooth normal move of games.
    here i tried.
    i tried to used another battery. it does the same.
    i tried another hdd. it does the some problem.
    any idea what was problem.
    thanks....
  • boyebaran
    • Sep 2015
    • 247
    • iran
    Re: hp G62 DA0AX1MB6H1 REV:H confusing problem.
    you must measure main voltage when you are using only battery and with adapter and compare together.(vcore-vga core,.....)
    • vivekkumarrai
      • Jul 2018
      • india
      lenovo t440 ploblim beep ram change on despile
      • vivekkumarrai
        • Jul 2018
        • india
        hp 9470 me screen on/off ho rah hai
        • motormayhem
          Lenovo T460 Only Charges on One Charger
          by motormayhem
          Laptop Question
          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
          05-12-2023, 01:46 PM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Johndill
          Dell Inspiron 7567 LA-D993P odd charger issue
          by Johndill
          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
          Here are the tested scenarios:
          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
          2. With the laptop off, plug in charger (LED says on) & the front charging...
          11-16-2022, 10:55 PM
