No power compaq parsario cp62 intel
  • joyson
    • Oct 2016
    • 13
    • Nepal
    i am new to electronics this is my first experience fixing dead laptop
    i am dealing with compaq parsari cq62 dead motherboard with power issue.
    My motherboard is daoax3mb6c2 rev:c I have attached the schematic I am using
    this board is completely dead I mean no light no fan running and
    adapter indicator also won’t turn on when I plug the ac adaptor but when I check
    connector(cn16) pin no 7 and 8 both pin have 5volts on page no 25.
    And I get 19volt on pin no 2 and 3 of upper mosfet PQ47 and 27.4 volt on pin no 1(page no 25)
    0 volt on pin no 1 and 2 of lower mosfet PQ51 and 27.4 volt on pin no 3(page no 25)
    But my always on 5volt and 3 volts are there on pl8 and pl4 (page no 26)
    I have checked my power button connector also all pins give the same voltage shown in schematics but
    When I press power button nothing happens I tried shorting the short pad (page no 23) but nothing happens. I don’t know where to check else please someone show me the guide line where to check.
  • khaahk
    • Dec 2013
    • 813
    • Estonia
    Re: No power compaq parsario cp62 intel
    https://www.badcaps.net/forum/showthread.php?t=27496
      03-31-2024, 02:12 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Andreas_de
      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
      by Andreas_de
      Hello!
      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
      04-12-2025, 10:38 AM
