Dell D620 Intel LA-2791 3 LED then power off fixed
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Dell D620, Intel integrated version, mainboard LA-2791. Problem: Powers on, power LED comes on, all 3 LEDs on keyboard come on (num, caps, scroll) then turns back off. No video. During this time all voltages are present.
    Solution: Desolder BIOS and flash using programmer. BIOS available on Dell's site here: http://www.dell.com/support/home/ro/ro/robsdt1/Drivers/DriversDetails?driverId=JPCCR]Dell Latitude D620, A07[/url], download file, open a command prompt window in the folder you downloaded it, type in "D620_A07.exe /writeromfile" and it'll spit out the binary. Flash ROM file using programmer.
    Or you can grab it in the attachment.
    If the board stays on after flashing but flashes Caps Lock and Scroll Lock LEDs with no video, power off, remove all RAM, power on without RAM and you should get the same flashing pattern. Power off again, put RAM back in, board should now display video and boot normally.
    Hope this helps someone.
    A working TV? How boring!
  • sopik78
    • Nov 2013
    • 520
    • Czech Republic
    Re: Dell D620 Intel LA-2791 3 LED then power off fixed
    Thanks for sharing
    • kalimuthu
      • Jul 2012
      • 19
      • india
      Thanks for help
      • kalimuthu
        • Jul 2012
        • 19
        • india
        I attach one more bios file
        • kalimuthu
          • Jul 2012
          • 19
          • india
          Here working bios
          • davodamirajam
            • Apr 2017
            • 9
            • iran
            Originally posted by kalimuthu
            Here working bios
            my d620 error is 2 right led is blinking
            ram detect problem
            after too many bios file
            start to re heat (not reball )simply heater gordak 945
            350 ° C for 2 minutes with Intel North Chip Flex Oil
            i mean very big chip up ram memory becuase vga +ram detection is that chip job
            now fixed
            any way tested bios dumped by ch341a uploaded to people
            d620 90 % nvdia chip problem
            but in my case north birge must heated
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • Mark01
              Dell Optiplex 7490 AIO - red power led after flash
              by Mark01
              Hi guys,
              This is my first post! 🚀
              I have no idea what I’m doing, but I’m learning by trial and error.
              I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
              07-04-2025, 12:54 PM
            • zlr8r
              Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
              by zlr8r
              hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
              Ill try and give as much info as I can.
              Dell Inspiron 17 (7786) Laptop
              Service Tag: 5J0NHT2
              Bios: 1.9.0
              When I received this , it would only flicker on the KB backlight for a second, then off and on.
              Then it started getting weirder!
              Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
              12-12-2023, 09:31 PM
            • LimesKey
              Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
              by LimesKey
              Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
              10-17-2025, 05:33 PM
            • seppde
              Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
              by seppde
              I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
              My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
              Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
              Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
              10-01-2024, 10:57 AM
