Acer E1-571G No Power
  • boyebaran
    • Sep 2015
    • 249
    • iran
    Hi
    please advice me about this problem.e1-571g no power
    i have not 3alwp and 5alwp.
    RT8205 and bq24725 replaced.KB9012 reprogrammed and not change.
    which point need to check?please help me.
    tnx
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: Acer E1-571G No Power
    first check Adopter 19v DC or Battery voltage on +B line...if OK then check +3VLP and 5VL on RT8205 PIN#8 and 17 then check 3v volt on switch and post the status.
    • boyebaran
      • Sep 2015
      • 249
      • iran
      tnx
      19 v is ok.3&5 vl is ok too.3.3 volt is ok on switch
      • boyebaran
        • Sep 2015
        • 249
        • iran
        PQ21:
        pin1 = 3.3v
        pin2 = 0v
        pin3 = 0v
        PQ21
        pin3 & 6 = 1.71v
        the pin 2 & 5 = 0V
        the pin 1 & 4 = the GND
        PU5
        pin1 = 1.71
        pin3 = 1.98
        pin6 = 1.71
        pin8 = 3.3
        pin9 = 5v
        pin13 = 3.7v
        pin16 = 19v
        pin17 = 5
        pin22 = 5
        • smali
          • Sep 2014
          • 287
          • Pakistan
          OK..just for checking remove PQ20 double FET and check always volts if not.
          Then short to ground PIN 6 and 3 ( drain) of PQ20 and check the 3 and 5 always on coil and post the status.
          • boyebaran
            • Sep 2015
            • 249
            • iran
            tnx smali
            shorted pin 6 to Gnd and 5 volt coming.but if i shorted pin 3 to gnd than not only 3.3 volt is not ok but also 5 volt gone to zero.
            i tested PL6 and PL7 ohm to gnd and PL6 have 800 ohm to gnd.i think 3.3 line have a problem
            • smali
              • Sep 2014
              • 287
              • Pakistan
              Originally posted by boyebaran
              PQ21:
              pin1 = 3.3v
              pin2 = 0v
              pin3 = 0v
              PQ20
              pin3 & 6 = 1.71v
              the pin 2 & 5 = 0V
              OK check short on both coils but you are missing something if PQ21 pin1 (collector) has 3.3v then PQ20 pin2&5 has definitely 3.3 voltage because both are directly connected but i think you count pin wrongly please confirm.
              • boyebaran
                • Sep 2015
                • 249
                • iran
                sorry my mistake pin1 pq21 is zero.pin2 have 3.3 volt
                • boyebaran
                  • Sep 2015
                  • 249
                  • iran
                  pin2 of pr79 have 5v but pin1 is zero
                  • smali
                    • Sep 2014
                    • 287
                    • Pakistan
                    yes pr79 0v poit is connected to transistor collector and that transistor pulled to ground.
                    ok install pq20 and remove only only pq21 transistor and check.
                    • boyebaran
                      • Sep 2015
                      • 249
                      • iran
                      after removing pq21 the pin1 is about 4.7 volt and pin 2 is 3.3v
                      • smali
                        • Sep 2014
                        • 287
                        • Pakistan
                        now check voltage on coils 3&5
                        • smali
                          • Sep 2014
                          • 287
                          • Pakistan
                          remove the transister and check 5 and 3 volts on coil
                          • smali
                            • Sep 2014
                            • 287
                            • Pakistan
                            install pq20 and remove pq21 and check 5 and 3 volts on coils
                            • boyebaran
                              • Sep 2015
                              • 249
                              • iran
                              pl 3&5 is 19 volt . without pq21` no voltage 3.3&5 v in coil
                              • boyebaran
                                • Sep 2015
                                • 249
                                • iran
                                my friend i have seem working motherboard and if u need measuring some voltage in ok motherboard please tell me.
                                thank you very much for your time
                                • smali
                                  • Sep 2014
                                  • 287
                                  • Pakistan
                                  PL5 and pl3 are +b voltage thats ok. are u installed pq20 and removed pq21?
                                  how many ohms to ground of pl6 and pl7?
                                  • boyebaran
                                    • Sep 2015
                                    • 249
                                    • iran
                                    i connected external 3.3 v to the coil(pl6) for short test and every things is normal(no Warm up any part )
                                    • smali
                                      • Sep 2014
                                      • 287
                                      • Pakistan
                                      also check the FETs pq16 and pq18 if you spears that FETs try to replace.
                                      • boyebaran
                                        • Sep 2015
                                        • 249
                                        • iran
                                        pl6 to gnd is about 800 ohm
                                        pl7 to gnd about 13 kohm
                                        in normal motherboard pl6 to gnd is about 5 k ohm
