Hp 255 +5VA Coil shorted
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Hi im working with this machine , the costumers say the problem has occurred from bad universal charger.
    Led of charge is on 3.3v on power button present but not power.
    I have check it and the 5v coil when i plug charge go on short with GND.
    Measured TPS51123 :
    vin 19v
    vreg3 3.3v
    vreg5 5v
    trip1, trip2 0.7v
    NOW
    DRVH1 is shorted
    DRVL1 is shorted
    Pin 2 of L308 is shorted when i plug adapter only .
    Replaced tps51123
    replaced q317 also checked p309 and the same problem .
    Any suggestion?
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: Hp 255 +5VA Coil shorted
    How can you tell that pin2 of L308 is shorted when adapter is pluged? Did you measure resistance while power was on board?
    ...the quieter you become the more you are able to hear...
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      Thanks for your reply.
      The consume of current is normal also charge the battery .
      With adapter on it i measured L308 have 8 ohm, L307 190 ohm.
      I have removed L308 and from pin2 of L308 to pin1 of PAD 306 i have short with ground please see my pictures .
      Sorry for my english.
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        you can't make measurement to gnd with power on , specially fets or coils :P or else they all will going to say they are all shorted .
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          best way to do that is simple , remove coilof 5 vawl , the injecct 5 volts on the pad itself , and see what is gettng hot , what is getting hot , simple remove and replace , but before replacing , chek the pns of the warming component to see if there is no short there as well .
          • gcomputers
            • Apr 2013
            • 509
            • Albania
            thanks Highpulse.
            i have tried this method yesterday, i have inject power with PSU 5v on shorted pin 2 of L308 but it warms slowly TPS51123 replaced again this chip with new one but the same short of 5v.
            do you think i have to inject power on pin2 or pin1 of L308?
            • highpulse
              i hate HP
              • May 2013
              • 1490
              • portugal
              ohh forgot to mention !!! lift coil l308 and inject on the pad :P
              • gcomputers
                • Apr 2013
                • 509
                • Albania
                just tried removed coil and inject on PAD 5v 1a and getting hot TPS51123. replaced 2 time this chip with new.
                This chip not have OUTPUT (DRVH1 is shorted when i connect adapter) .
                • gcomputers
                  • Apr 2013
                  • 509
                  • Albania
                  any suggestion ..........
                  • reessi
                    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                    by reessi
                    Hello:
                    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                    I started on the ACER:
                    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                    10-29-2024, 11:31 AM
                  • Yanleb
                    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                    by Yanleb
                    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                    D608, good
                    D618 RF101L4S, good (See warning 1 below)
                    D619 RF101L4S, good (See warning 1 below)
                    D865 RF101L4S, shorted (See warning 1 below)
                    IC464 Inverter HA MC74HC1G14, shorted...
                    03-09-2020, 12:00 AM
                  • modtool
                    HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                    by modtool
                    Hi to all,
                    the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                    I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                    I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                    04-01-2025, 08:22 AM
                  • AppleLover123
                    Acer Nitro 5 comes on then goes off
                    by AppleLover123
                    Hey guys,
                    i've got this laptop from a friend who gave it to me in a dead state.
                    The laptop wasn't working at all so i've began my search on the 19V power rail.
                    It was shorted to ground so i injected voltage and the only thing getting hot was my ground clip from my power supply.
                    I found that the +1.05V Rail for the Chipset was shorted. i removed the coil and it was shorted on the power delivery side.
                    The pch seems fine bc the rail has over 50 ohms after i removed the coil.
                    Still nothing was getting hot so i suggested the chip must...
                    10-09-2025, 04:51 PM
                  • barry101
                    Apple 820-3662 VCore shorted to ground.
                    by barry101
                    Hi, Would appreciate some help.
                    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                    Get charger light but no fan spin or chime. No liquid damage.
                    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                    06-24-2025, 07:34 AM
