Clevo W740SU Problem switching on (aka Schenker S413, System76 Galago UltraPro)
  • rash.m2k
    • Apr 2010
    • 64
    Hi All,
    My laptop has developed a fault, when I press the power button its switches on I can hear the disk spin.
    If I have the power supply plugged (or keep the power button held down) it will keep doing this on a loop until it switches on.
    Nothing appears on the screen at all.
    I do have a 2TB spinning disk a 256GB sata and 16GB of ram in this - this will increase power consumption, maybe this tipped it over the edge?
    What do you think could be the issue?
    I'm based on the north west, UK so if you are close I'd be happy to pay for your time to take a look at this?
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: Clevo W740SU Problem switching on (aka Schenker S413, System76 Galago UltraPro)
    I there , i dont think this could be a issue due to power problem .. this clevo must have an adapter at least 7 to 9 amp .
    alltough , computer beeing in loop during beggining , does seem to me , bad config in bios , making it to loop start , try removing battery and therefore cmos battery for some good minutes , (also do not attach power source during htis time :P
    i've been having clevos for a while , and somethimes they can be a bit annoying .
    but mainly bios and starter ICS damage often
    • rash.m2k
      • Apr 2010
      • 64
      Hi mate,
      tried this, even had the battery and the bios battery out for a few days and it's still doing the same thing.
      Not really sure what the problem is.
      FYI I've attached the repair manual for this laptop, hopefully should help in diagnosing this issue?
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        if pl4 pl5 are 3.3 and 5 volt , check if they comes up after pressing power botton and if they go down within a second or stay up for a while.
        • rash.m2k
          • Apr 2010
          • 64
          OK pal I know it's been a while, I've got the multimeter out and checked it.
          They seem to down down within a second or so, I have to put my meter on max voltage so I can see what the voltage actually is because the laptop keeps looping round and round. PL4 goes up to 5.18v and pl5 goes up to 3.271 volts,
          (there are two pins and on one side the voltage is slightly lower.....).
          This is with everything removed, only the montherboard, power cable, and on/off switch (there some secondary circuit boards which I also left on as they were clipped in).
            03-31-2024, 02:12 PM
          • danon93x
            Need BIOS System76 Gazelle (gaze14) a.k. Clevo NH70RA
            by danon93x
            Like in title in need working BIOS to System76 Gazelle (gaze14). It's a rebrand of CLEVO NH70RA
            Maybe some can help me
            02-12-2025, 11:58 PM
            07-01-2024, 06:34 AM
          • Günter Schuch
            searching for Schematics & Boardview for Clevo P641HK1
            by Günter Schuch
            hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
            Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
            05-14-2025, 06:34 AM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
