Lenovo b450 no power help
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello everyone....
    im just having a problem with this mobo.
    there is no 3.3v and 5v alw in Coil. but in DC/dc IC is Present
    i dont know why it is not going to coil.
    i can't find the issue...
    i check all coil no shorted
    flash bios still no power
    checked power switch ok.
    19v present
    clean mobo still no power
    reflow vga chips still no.
    pls help guys...
  • rickybucalan
    • May 2013
    • 322
    • philippines
    Re: Lenovo b450 no power help
    bios file guys?
    • electronica
      • Apr 2014
      • 88
      • algeria
      1mn of searching on google
      bios : http://www.alexlaptoprepair.com/wp-c...enovo_b560.zip
      schematic:
      flash the EC_bios first .
      • electronica
        • Apr 2014
        • 88
        • algeria
        the EC is a common problem in this model .
        • BlueMidnight
          • Jan 2015
          • 489
          U47 has 4 outputs:
          3V/5V LDO (low current)
          3V/5V switching/buck (high current)
          Your LDO outputs are working. Your switching outputs are not. The LDO outputs do not go through the coils.
          It's a good idea to completely investigate U47 before assuming what the problem is. In fact, I would just check the voltages on all 24 pins and then compare that to the schematic.
          The main question is: Are the switching outputs enabled? (pins 1 and 6 high). If they are enabled but not outputting voltage, then the problem must be in or around U47. For example, U47 itself might be bad, one of the 4 MOSFETs (U22, U23, U28, U29) is bad, or there is a short on one of the outputs.
          If the outputs aren't enabled, then check the S5_ENABLE signal. You should only worry about the EC in this case if there is no S5_ENABLE signal.
          • rickybucalan
            • May 2013
            • 322
            • philippines
            schematic:
            i think there is only main bios of this mobo. can't find EC bios.
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              there is only main bios of this mobo with 2mb
              • rickybucalan
                • May 2013
                • 322
                • philippines
                thanks buddy but it won't works too... still no power.
                • rickybucalan
                  • May 2013
                  • 322
                  • philippines
                  Originally posted by BlueMidnight
                  U47 has 4 outputs:
                  thanks. i did replaced U47 but it still dont work. i guess it not the problem.
                  about 4 mosfets i didn't find any short with them.
                  • electronica
                    • Apr 2014
                    • 88
                    • algeria
                    yep ..sorry i mad a mistake
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      Soldering should be avoided whenever possible. It might make things worse by accident. Or if you put a new component in a bad circuit, it will just fry the new component. Guessing is rarely required. You need to find the problem logically. Start by measuring the voltage on all the pins. Especially on 1 and 6 in this case.
                      MOSFETs can short in 3 different ways: source-drain, gate-source, and gate-drain. Remember to test for all 3.
                      • rickybucalan
                        • May 2013
                        • 322
                        • philippines
                        i don't know what to say.. i are so amazing Bluemidnight.... thank u so much for your help...
                        i miss that to test gate-source and gate-drain. i found 2 mosfets short on (gate-source).
                        but after removing one mosfet and test it wasn't short. so i put it back then tried its works... its could be bad contact may be.
                        i learned lot from u bluemidnight thank u again.....
                        God bless.
                        • NIKHILKYOHANNAN
                          • Mar 2015
                          • 6
                          • india
                          hello everyone....
                          First i got the problem not powering on and i found one SMD capacitor Shot to ground which is DCBATOUT signal,After replacing this capacitor I got the dispaly.but it motherbored now showing Auto power on. Cmos battery voltage has 3.3v also clear the Cmos Battery,but not succeed.
                          hope anyone can help me..T I A
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • Mita99
                            Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                            by Mita99
                            Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                            Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                            Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                            04-27-2025, 07:20 PM
                          • Dr.d
                            Help please..Lenovo ideapad 5 14itl05 power and charging problem
                            by Dr.d
                            I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                            Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                            04-05-2024, 11:48 AM
