Lenovo G50-30 Completely dead, no lights at all.
  • Andreasbest
    • Aug 2014
    • 1189
    • Hellas ( Greece )
    Re: Lenovo G50-30 Completely dead, no lights at all.
    I understand, i will buy you beers when i visit Chicago again
    Please if you have time check my other thread, it's a Acer 5810T and it's the 3rd and last laptop that is completely dead.
    Thank you once again!
    • didutgendut
      • Jun 2017
      • 20
      • Indonesia
      Originally posted by BlueMidnight
      Okay good, now we know where the 20V stops.
      Next, measure voltage on PQ302 pin 4. If it's 0V then PQ302 is probably bad. If pin 4 is around 20V, then unplug the power and check for a short between PQ302 pins 5-8 (they're all connected) and ground.
      If there is a short, then it will be time for a fun short-finding expedition.
      If there is no short, then measure all pins on PU301 (20 pins total). Also measure all pins on PQ306, PQ308, PQ309, and PQ310 (they each have 6 pins).
      Waiting for messages back and forth is the longest part. Better to do as much measuring as possible.
      I'm off to bed. Be back later.
      hi, i have the same problem here. In my case, yes there is short between PQ302 pin 5-8 and the ground. would you please help me what i have to do next?
      • kgerakopoulos
        • Jun 2017
        • greece
        i have pq301 and pq302 15v , so i believe that those two must be replaced ?
        • kgerakopoulos
          • Jun 2017
          • greece
          i get 15volt on PQ301 and PQ302, is it ok ?
          • qdikyp
            • Aug 2015
            • Bulgaria
            Thank you, your topics save my dead laptop!
            • janopitono
              • Nov 2017
              • slovenia
              #26
              Originally posted by Andreasbest
              I tested PC307 on circuit measures 180Ω ,when i removed it i got 10MΩ and was increasing for as long i was taking measure 11MΩ,12ΜΩ,13ΜΩ and so on.
              PQ304 has 20v an all three pins, PQ305 has 20v only on pin 1,PQ301 has 20v on all pins.
              I removed PQ304 from circuit and gives no measures at all, with black on pin 2 and red on 1-3 and the opposite with multimeter in diode mode.
              Just to make sure, PQ304 pin 2 is the one that is directly connected with the pin 1 of PQ305, correct?
              Also in Ω mode the PQ304 shows various resistance on all pin combinations, i think the pin 1 should not give any resistance at all.
              Now i'm confused though, how is it possible the PQ304 to be faulty but the same time to have output 20V to PQ305 that hasn't output at all?!
              I have exactly the same problem with my G50-30. However since I'm newbie and my proffesion is of totaly different type, I can not find where this capacitior (PC307) is located on the circuit. I simply can not find it
              • Dimitrios
                • Nov 2013
                • 127
                • Greece
                #27
                Also for me PQ302 mofset was broken after some measurements I took and stopped the current to flow through. Replaced it and now I got a proper opening laptop!
                • Idegen
                  • Aug 2019
                  • Hungary
                  #28
                  Hi guys.
                  Thank you for the recording. This page is great!
                  Great help in troubleshooting.
                  • Manta225
                    • Aug 2019
                    • United Kingdom
                    #29
                    Hi , new here. Happy to see this post as will help me. as ive just stuffed same board. After a short on power supply ( Frayed cable due to hinge problem) i put power 20v on the dc In......However not realising i put 20 v to centre pin Doh...Yes we had smoke.
                    PQ301 Is completely fried and also notice it may have got to the super IO as it stinks.
                    Onwards and upwards :-)
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      20V to the centre pin-KBC is 100% fried.
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        #31
                        that's right the center pin of the lenovo laptop with this kind of supply is directly connected to the super io so say goodbye to your super io. its difficult to find replacement of that ic because it has a built in eeprom program specially build for the lenovo brand. gud luck with that!!!
                        Never stop LEARNING because life never stops TEACHING!
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          IT8586e is the kbc you are talking about?? Its very easily available in market and programming the kbc is not difficult if one has proper tools.
                          • Duranitron
                            • Jul 2014
                            • 544
                            • Philippines
                            #33
                            oops sorry about that confused with the super io with kbc my bad!
                            • Andreasbest
                              Lenovo Thinkpad T14s completely dead.
                              by Andreasbest
                              Hello.
                              I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                              I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                              Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                              Thank you in advance!
                              Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                              03-19-2024, 03:18 AM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                            • Andreasbest
                              Lenovo T490s completely dead
                              by Andreasbest
                              Hello!
                              I received a fantastic T490s that is completely dead, after i removed the back cover i noticed a totally fried cap (attachement) pic, i remove it and cleaned the pcb, seems undamaged, although the nearby caps are shorted, PU1001 looks physically undamaged.
                              Any advice please?
                              Scehmatics, boardview and damage picture in attachement....
                              02-21-2023, 01:47 PM
                            • bialag
                              Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                              by bialag
                              I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                              Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                              03-25-2025, 05:56 PM
                            • max-power
                              Dell E6540 laptop completely dead after dssasembly
                              by max-power
                              Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                              that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                              After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                              03-24-2025, 08:49 AM
