Howto find shorted component
  • sasser
    • Dec 2012
    • 365
    • Malaysia
    1. Use injection current please anyone disscuss the best method and workflow
    2. Just look at the board and touch everywhere and try and error - u dont know which one culprit.
    3. Read schematic and judge itself which component to ground shorted and change. Its took long time
    Or combination threes method? What your ecperience
  • mariushm
    • May 2011
    • 3799
    Re: Howto find shorted component
    Get a thermal camera and see what's hotter than normal.
    If you suspect a shorted component is in a specific area then ... get an air can flip it with the nozzle down and spray the area, instead of air you'll spray the cooling gas inside instead over the board and basically freeze the area (if you're not careful you could even create ice/snow on chips, such cans are quite effective).
    Then, run the board (if possible from a current limited power supply) and see which component warms up much faster than others. This for example works very well for sram/dram chips, to spot one that's shorted or faulty from a bunch of them.
    For resistors or capacitors, just probing with a multimeter can work.
    Testing with current can work, if you have a very good multimeter, by measuring the resistance of the trace at specific points and where there resistance changes substantially you know there's a problem
    There's also an issue of cracked ceramic capacitors or resistors that short only under some conditions like when board heats up after hours of use and may slightly expand. A thermal camera would be great for such cases .. you'd use a hair dryer or paint stripping gun to warm the board in a place you suspect there's such faulty components while checking with thermal camera and your eyes to see if some smoke or overheated smd component pops up.
    • sasser
      • Dec 2012
      • 365
      • Malaysia
      Good explanation and thanks i learn new trick n tips from mariushm
      • rievax_60
        • May 2012
        • 897
        • australia
        I have been using a method explained here starting at post #25, https://www.badcaps.net/forum/showth...t=46808&page=2
        I find shorted capacitors quickly if it is a faulty capacitor.
        You need to have a multimeter with 10uv resolution for this method to work and understand the relationship between voltage, current and resistance.
        Whatever you do or are told to do, do not apply more than 1 volt from an external supply.
        • shortchange
          • Jan 2012
          • 27
          To find a short or multiple shorts.
          Say the 3.3v supply has 4 ohms.
          attach your ohm meter to the 3.3 volt line.
          And using chilling spray or a heat gun.
          The components that cause a change in the ohm meter is or are most likely at fault.
          • sasser
            • Dec 2012
            • 365
            • Malaysia
            if use adjustable psu easy to see spike current either its high or not. the trend is if 19v shorted rail about 3.0-5.0A and if 3v shorted less then 3A current. 1.8v also less then 3A. thats i determine the problem.
            • im_trying
              MSI GF65 Thin doesn't turn on, shorted on dc-in, how to find the culprit?
              by im_trying
              Hi, thanks for helping.
              The motherboard is from a gaming laptop, msi gf65 thin 10ue, 16W21/11S.
              For starters, it doesn't power on. I measured a "short" on the second DC-IN mosfet, right around the charging port but I don't know how to find the component that's shorting it.
              I already tried checking the mosfet for internal shortage (by desoldering and measuring) but no short. The drain on the motherboard is the one that's shorted, next to the gate (that's not shorted).
              The photo below shows this better than words.
              Thanks for anyone...
              05-12-2025, 04:16 AM
            • mkdj
              Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
              by mkdj
              Dear all,
              Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
              I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
              I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
              08-11-2025, 04:55 AM
            • Lee M.
              IR night vision goggles to find shorted panel line?
              by Lee M.
              Has anybody tried to use IR night vision goggles or other thermal imaging device to find a shorted line in a ribbon cable going from a panel driver board into the panel? I would think the shorted line would get hotter than the other lines and might just show up on a thermal imaging device. Just wondering if anyone has tried this and if so did it work?
              11-10-2023, 03:19 PM
            • Yanleb
              Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
              by Yanleb
              Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
              I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
              D608, good
              D618 RF101L4S, good (See warning 1 below)
              D619 RF101L4S, good (See warning 1 below)
              D865 RF101L4S, shorted (See warning 1 below)
              IC464 Inverter HA MC74HC1G14, shorted...
              03-09-2020, 12:00 AM
              by Vesko356
              08-11-2023, 03:27 AM
