Lenovo B50-30 HDD and DVD no power
  • rtstorm
    • Feb 2012
    • 972
    • Croatia
    hello, i have this Lenovo B50-30 (ZIWB0/B1/E0 LA-102P) that have water damage.
    I clean mobo and laptop turn on but HDD wont spin, and DVD wont open.
    I check voltages on HDD and it have only 3.3V and 0.5V.
    What do you think this could be?
    ...the quieter you become the more you are able to hear...
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Lenovo B50-30 HDD and DVD no power
    you must found 2 voltages in lenovo 3.3v and 5.10v
    als so
    • rjcp
      • May 2016
      • 10
      • India
      check the +5_vs supply on the 14,15,16 pin of the hdd connector (SATA HDD1 Conn.). if it is 0v, check R129 resistor.
      • rtstorm
        • Feb 2012
        • 972
        • Croatia
        Hey i found that U11 was burned, i remove it and look the pads are burned.
        Is it possible to bypass this MOSFET?
        • lezsimply
          The Wanderer
          • 659
          • Philippines
          I think you can still scratch off some copper trace from the paths to create new solder points then u can use tiny wires to jumper it.
          • rtstorm
            • Feb 2012
            • 972
            • Croatia
            Yes but mosfet legs are gone, those 3 legs on mosfet is broken
            • lezsimply
              The Wanderer
              • 659
              • Philippines
              oh do you mean mosfet itself or the solder pads? You can check image I attached. The center pin might give you a problem though.
              • rtstorm
                • Feb 2012
                • 972
                • Croatia
                Look, i am missing legs on mosfet
                • lezsimply
                  The Wanderer
                  • 659
                  • Philippines
                  Need a replacement for that. I usually salvage those from scrap boards.
                  • rtstorm
                    • Feb 2012
                    • 972
                    • Croatia
                    i will order it, i found it for 4$. Will post result when i receive the part.
                    Thank you all for now,
                    • rtstorm
                      • Feb 2012
                      • 972
                      • Croatia
                      hey i manage to replace the MOSFET. I have 5V and 3.3V on output now. But now my laptop wont show display I do not think this issue is related to this MOSFET.
                      Will try to flash new bios, and also i found that battery (3V battery not laptop battery) holder is broken.
                      Can this be problem and reason why laptop wont start? Because it do not have this 3V from battery?
                      Also non LED indicator wont blink, only turn on LED on pwr button
                      • rtstorm
                        • Feb 2012
                        • 972
                        • Croatia
                        I try to flash the Bios but it is 1.8V chip. So i do not have 1.8V adapter (have only 3.3V)
                        Waiting for adapter to arrive.
                        • rtstorm
                          • Feb 2012
                          • 972
                          • Croatia
                          Hey i receive my 1.8V adapter but programming was unsucessful. Software tell me to check the pin.
                          i use TL866CS and this adapter
                          • rtstorm
                            • Feb 2012
                            • 972
                            • Croatia
                            hey i managed to fix this (it was bad RAM slot)
                            All is working now exept laptop wont charge battery. When i plug in charger (laptop is turned off) and start it it wont charge battery. But when i start laptop without battery and then plug battery (when laptop is ON) it will start charging
                            • rtstorm
                              • Feb 2012
                              • 972
                              • Croatia
                              Hello, i find that PU602 getting really hot. i found that on pin 8 (IN) get 19V. is this normal.
                              Pin 8 is maked on schematics as "B+_1.0V"
                              Also i found that only pin 3 (ILMT) is shorted to GND but i this it should be shorted to GND.
                              Alse i found boardview of this board, so i attached it.
                              • Fabbrone
                                • Jun 2015
                                • 158
                                • italy
                                it was bad RAM slot, me too
                                • Mita99
                                  Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                  by Mita99
                                  Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                  Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                  Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                  04-27-2025, 07:20 PM
                                • Capacitorial
                                  Powersupply has all the voltages - Monitor still no power
                                  by Capacitorial
                                  Hello guys,
                                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                  The weird thing is, that the Power LED is powered over the TCON board.
                                  On The TCON...
                                  12-28-2024, 02:12 PM
                                • Dr.d
                                  Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                  by Dr.d
                                  I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                  Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                  04-05-2024, 11:48 AM
                                • WTFRules!
                                  Lenovo IdeaPad Slim 3 15IAN8 won´t power on after power off without AC charger plugged in
                                  by WTFRules!
                                  Hi!
                                  I´ve this Lenovo IdeaPad Slim 3 15IAN8 with mainboard (KS480 / KS580) NM-E901 Rev 1.0
                                  I receive it for repair from another shop and it had shorted EC IT8227VG-256
                                  After replacing it and programming it with SVOD 4 (wich is new to me as I bought it in this week) the laptop is working fine now... BUT
                                  Once power off from windows, it will not turn on again. When off and the power on button is pressed, a white led turns on and that´s it.
                                  But if you plug the charger, then all the keyboard LEDs will lit and then you get image on screen and it boots normally....
                                  11-04-2025, 02:50 PM
                                • SoulFreeze
                                  Lenovo Slim Pro 7 14ARP8 83AX No Power
                                  by SoulFreeze
                                  Hello All, I have a Lenovo Slim Pro 7 14ARP8 83AX, Board No NB6369A_MB_V5
                                  Behavior - Pressing power button results in three second led blinks on the button,
                                  Connecting charger lights up orange as normally would while charging.
                                  Connecting charger without battery blinks orange.
                                  No fanspin.
                                  Tried flashing bios, no change.
                                  I inspected the board and found a burnt component on the USB / Power button daughter board. I assume the comonent was an esd protection diode as it was on the USB A port power rails. removed the component but still exhibits...
                                  05-01-2025, 09:04 PM
