Dell m5110 keyboard and touchpad not working
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Dell m5110 keyboard works in bios but as soon as it starts to load os it doesn`t work any more...it doesn`t work when you load os from live cd or usb flash...
    I have changed kbc but problem remains...Any thoughts before messing with fch ???
    Edit :tried new keboard and tochpad, problem remains...
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: Dell m5110 keyboard and touchpad not working
    have you external keyboard or mouse in usb port? what the result
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      it works ok with external...
      • Djosla
        • Dec 2012
        • 246
        • Montenegro
        fch changed all good...
        • NotEnough
          Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
          by NotEnough
          I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
          What I've Tried So Far:
          • Reseated the cables.
          • Reinstalled AWCC and AlienFX services.
          • Attempted BIOS downgrade but no improvement.
          • Inspected ribbon cables for damage.
          • Explored the possibility of BIOS or
          10-19-2024, 01:34 AM
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
        • djty
          MBP 2013 15" 820-3787 no keyboard, no touchpad
          by djty
          Device: Laptop
          Brand: Apple
          Model: MacBook Pro
          Board number: 820-3787-06
          Problem:
          • no keyboard, no trackpad
          • Fans Spinning fast
          Hello everyone. The MacBook pro late 2013 keyboard is not responses even when trackpad is disconnected.
          no reaction on KB, only power button andd ctrl alt shift, which are on keyboard connectore are separately on the KB pinout KB backlight is present the PP3V3_S4 and PP3V42_G3H one keyboard connector J4813 are present on keyboard
          external USB keyboard works Should touchpad be connected to motherboard for KB to be working?
          03-17-2025, 11:03 AM
        • playit
          ps/2 port keyboard dead ? p5ql pro / ethernet cable light
          by playit
          my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
          my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
          few years back ps2 mouse stopped working, but ps2...
          12-23-2024, 06:05 AM
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
