Hitachi hdd locked
  • mitu_sharma
    • Jul 2015
    • 182
    • india
    Hitachi hdd locked
    Hi friends need your help
    I recieved asus mini laptop which is protected by user hdd password I tried many tools but no result out
    Can u suggess me what should I do.
    pls give ur suggestions as soon as possible thanks.
    • 30979
    Re: Hitachi hdd locked
    there is software that can send a reset command using another computer, but it only works on some hardware - and it will completely wipe the drive.
    • mitu_sharma
      • Jul 2015
      • 182
      • india
      hi stj
      can u tell me software name or link pls
      • Sparkey55
        • Jan 2010
        • 1523
        HDAT2 comes to mind.
        • mitu_sharma
          • Jul 2015
          • 182
          • india
          okkkk
          thanks
          • fzabkar
            • Mar 2009
            • 772
            Search for ZU at the HDD Oracle forum.
            • mitu_sharma
              • Jul 2015
              • 182
              • india
              nothing happen with hdat2 and zu tool
              what is the other way to unlock the drive?
              • Sparkey55
                • Jan 2010
                • 1523
                Please describe in step with full detail how you used HDAT2 without successful results.
                • Sparkey55
                  • Jan 2010
                  • 1523
                  As fzabkar stated above the HDD Oracle forums are the best place to ask these questions. Good luck with your drive.
                    • 30979
                    use a different computer or DONT use a usb adapter.
                    you can usually only send the reset command through a real sata interface.
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      That is why that forum was suggested. A good one to learn from. I have repaired a few drives that I thought were goners and unlocked some sata drives from DVRs and such.
                      • mitu_sharma
                        • Jul 2015
                        • 182
                        • india
                        i am sorry to say the laptop is return to customer
                        • tfatt
                          Hitachi Flora Se210 Bios Locked x3
                          by tfatt
                          Hi There,
                          Anyone able to help me to look and remove the bios password on this Hitachi Flora Se210 model, (bios password locked).
                          Attahced the dump file and screenshots of the bios model....
                          10-22-2021, 03:22 AM
                        • lallollas
                          Acer chromeBook c733-c3uy Locked need help
                          by lallollas
                          chromebook locked without google account i alreadu edit rom and change value enrol 1 to 0 and still locked need help
                          model n18q5...
                          04-09-2024, 08:14 AM
                        • dr_crx
                          Dell 7740 Bios locked J3JSD43-8FC8
                          by dr_crx
                          Hello i need help please
                          i have DELL 7740 ST: J3JSD43-8FC8
                          i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                          anyone can help to show its location on motherboard please.
                          i attached the results file the IC i read is : winbond 25q80dvsig
                          i don't know if its the needed bios or another bios on the motherboard.
                          thank you in advanced for your help...
                          07-11-2025, 12:22 AM
                        • massimomax
                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                          by massimomax
                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                          Post in English !!!
                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                          02-28-2025, 07:27 AM
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
