Hitachi hdd locked
  • mitu_sharma
    • Jul 2015
    • 182
    • india
    Hitachi hdd locked
    Hi friends need your help
    I recieved asus mini laptop which is protected by user hdd password I tried many tools but no result out
    Can u suggess me what should I do.
    pls give ur suggestions as soon as possible thanks.
    • 31247
    Re: Hitachi hdd locked
    there is software that can send a reset command using another computer, but it only works on some hardware - and it will completely wipe the drive.
    • mitu_sharma
      • Jul 2015
      • 182
      • india
      hi stj
      can u tell me software name or link pls
      • Sparkey55
        • Jan 2010
        • 1523
        HDAT2 comes to mind.
        • mitu_sharma
          • Jul 2015
          • 182
          • india
          okkkk
          thanks
          • fzabkar
            • Mar 2009
            • 772
            Search for ZU at the HDD Oracle forum.
            • mitu_sharma
              • Jul 2015
              • 182
              • india
              nothing happen with hdat2 and zu tool
              what is the other way to unlock the drive?
              • Sparkey55
                • Jan 2010
                • 1523
                Please describe in step with full detail how you used HDAT2 without successful results.
                • Sparkey55
                  • Jan 2010
                  • 1523
                  As fzabkar stated above the HDD Oracle forums are the best place to ask these questions. Good luck with your drive.
                    • 31247
                    use a different computer or DONT use a usb adapter.
                    you can usually only send the reset command through a real sata interface.
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      That is why that forum was suggested. A good one to learn from. I have repaired a few drives that I thought were goners and unlocked some sata drives from DVRs and such.
                      • mitu_sharma
                        • Jul 2015
                        • 182
                        • india
                        i am sorry to say the laptop is return to customer
                        • tfatt
                          Hitachi Flora Se210 Bios Locked x3
                          by tfatt
                          Hi There,
                          Anyone able to help me to look and remove the bios password on this Hitachi Flora Se210 model, (bios password locked).
                          Attahced the dump file and screenshots of the bios model....
                          10-22-2021, 03:22 AM
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                        • winbond
                          dell xps 14 9440 absolute locked
                          by winbond
                          hello, please unlock my file. absolute enabled
                          ST:87TG544
                          board number: LA-M892P...
                          10-25-2025, 06:51 AM
                        • wolf1976
                          hitachi 50hk5600 problem with display
                          by wolf1976
                          hi
                          i have the above tv and the display starts distorts the display at only in applications like you tube
                          after and on the didital channels
                          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                          09-13-2025, 02:26 PM
                        • lallollas
                          Acer chromeBook c733-c3uy Locked need help
                          by lallollas
                          chromebook locked without google account i alreadu edit rom and change value enrol 1 to 0 and still locked need help
                          model n18q5...
                          04-09-2024, 08:14 AM
