[help]dv9740el no backlight after hp logo!!!
  • phantomEVO
    • Mar 2013
    • 488
    hi, please help me
    when i power on, i can see clearly the hp logo then all it's dark.
    if i enter into the bios i see it, but very very very dark
    if i put an external monitor i can't see the bios, but when windows boot, i can see clearly the operating system on the external screen and use the pc without problem!
    another strange thing, soon before windows boot, the arrow point appears for some seconds than disappear
    another strange thing: when i disconnect the external monitor, some times the internal monitor power on and i can see clearly!
    if i disconnect the battery and the power chord, holding power button and the i reinsert the power chord, i can boot into the bios and see the bios for 2/3 second
    i've try another screen and another inverter: still the same
    here's the problem
    https://www.youtube.com/watch?v=o6BGUJU8U_s
  • phantomEVO
    • Mar 2013
    • 488
    Re: [help]dv9740el no backlight after hp logo!!!
    found the problem! i has bought this "dead" notebook for 10 euros. it was with black screen so i've bought another notebook with perfect screen but dead motherboard. i've changed the screen and got the problem. now i've done some experiment and found that
    the old screen with the cable from the "newer" screen, boot up and works flawlessly.the newer screen with the cable of the "old" doesn't boot. so
    the old screen with the new cable boot perfect
    the new screen with the new cable boot perfect but then i not have backlight
    i wondering why the new screen work correctly and if i can be able to fix it
    the old screen is b170pw06 v2
    the new is ltn170x2-l02
    • LP_tekh
      • Oct 2015
      • 95
      • Laos
      First, try to disconnect and reconnect the screen cable on both side.
      Check the ccfl bulb or inverter.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • arbitarytwist
        Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
        by arbitarytwist
        Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
        Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
        03-01-2025, 01:16 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • taslan
        Surface 7 Pro wont boot, shows Logo and immediately turns off
        by taslan
        as stated in the title, my surface 7 pro wont boot anymore.
        When i press the power button it shows the square windows logo for a second and immediately turtns off again.
        I dont even have a chance to get into bios or boot from usb.
        While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
        I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
        Bought it directly from microsoft and used it now and then and only...
        01-16-2025, 01:25 AM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
