Alienware 17 (R1) CPU not detected
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Ok, i swear, i'm running out of ideas
    So, i've had this Alienware 17 R1 (Haswell) brought to me. Allegedly, the owner tried to undervolt the cpu(?) because he was having overheating issues. Odd / unlikely, but fair enough.
    Initial status - laptop turns on (ie. the lights & hdd's & stuff), but that's about it. No POST, no backlight, no beeps, nothing at all, with or without RAM.
    Step taken: fresh BIOS chip, programmed with a dump found online (de-whitelisted).
    Result: Still no backlight, but "at least" now i get series of 7 (seven) beeps, which in Dell / Alienware language, means the CPU doesn't get detected.
    Since the cpu had supposedly been messed with, i figured i'd try to eliminate that variable. Stock it had an i7-4940MX; i found an i3-4000M for not too much money, to use as a test-cpu. No dice, same 7-beep stuff.
    I've yet to probe ALL the voltage rails, but the ones i could reach on the top of the board, all check out - 5v / 3.3v main rails, the 1.35v and 0.675v for the RAM, 1.05v, 1.5v. At least, at the point of generation, anyway.
    I'm getting 1.7v on the VCC_CORE rail, which is a bit on the high side, and from that Th3_un1qu3 tells me, that happens when the cpu isn't detected (properly).
    I'm attaching the schematics / service manual for this board.
    So... What the hell's the "cpu detection protocol" in computers?
    Now that i think about it, i'm almost starting to doubt the "validity" of that bios dump i found. But then again, complaining about the cpu is still more than it did when it first came in...
    Any ideas, anyone?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: Alienware 17 (R1) CPU not detected
    hi check voltage on: pq502 pin 5-6-7-8 , pl501
    pq506 pin 5-6-7-8 , pl502
    pq510 pin 5-6-7-8 , pl503
    then check carefully pu500 voltages. pin 17 , 8 , 3 , 5 , 16 , 22, 23 for now.
    also pu501 voltages on pins,
    edit: before check all those voltages, check pu501 voltage first and report back
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Umm... If you'll read a bit more carefully, i *DO* have Vcc_core present, but it's a bit high.
      Also, i should add that even without the fan connected, the cpu heatpipe gets warm. Not hot, i can keep my hand on it all day long, but you can tell it's on.
      But fine, just so you won't say i'm not cooperating:
      CPU_B+ = 15,7v (i'm running it off the battery), that goes to the drains of all those three FETs
      On to PU501.
      17 - 15,6v (it's the B+)
      8 - 1,7v (FB)
      3 - 3,3v (Pgood)
      5 - 0v (VR_hot#)
      16 - 5,1v (5Valw)
      22 - 0,6v (PWM3)
      23 - 5,1v (5Valw)
      Hmm... That pin22 voltage is a bit low, considering it's supposed to be connected pretty much directly to the 5v rail via PR523.
      Edit: Nevermind, i mis-counted - that 0,6v was on pin 21, in fact...
      • dellxps15
        • Feb 2014
        • 1591
        • italy
        On to PU501.
        8 - 1,7v (FB)
        3 - 3,3v (Pgood)
        5 - 0v (VR_hot#)
        16 - 5,1v (5Valw)
        22 - 0,6v (PWM3)
        23 - 5,1v (5Valw)
        u must read before my edits: first report voltage on pu501; u are reporting voltage on pu500
        pr523 must be 0 omh. remove power to board and check its value.
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Oops, typo - yes, that was PU500
          See the edit in my previous post.
          In fact, PR523 shouldn't be there at all - that's what the @ symbol means, next to it. And if that PWM signal was tied to 5v, PU501 wouldn't be doing anything
          NOW let's see PU501.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            PU501:
            Pin 1 = 2.1v
            Pin 2 = 6.2v
            Pin 3 = 0.6v
            Pin 5 = 4.4v
            Pin 6 = 5.1v
            Pin 7 = 5.1v
            Pin 8 = 1.7v
            Scope traces look pretty normal too - high duty-cycle on the low-side gate, low duty-cycle on the high-side gate, PWM's there.
            Somehow, i kinda doubt this is a Vcore issue...
            • dellxps15
              • Feb 2014
              • 1591
              • italy
              qc3 voltage ? page 11 on schematic
              • Khron
                • Sep 2006
                • 1350
                • Finland
                There are two rows of caps "inside" the window of the metal backplate, under the cpu. On one side it's the Vcc_core decoupling caps, and on the other side there are four 0805 caps, decoupling the VDDQ - i DO have 1.35v on those.
                Like i said in my first post - at least from a power point of view, i have all the main rails, as far as i can tell.
                • Djosla
                  • Dec 2012
                  • 246
                  • Montenegro
                  I can assure you that 7 beeps on dell never had anything to do with cpu...it was always gpu/nb problem although it states cpu problem on dell site...
                  • Khron
                    • Sep 2006
                    • 1350
                    • Finland
                    Well, that's kinda-sorta what i figured, since it kept doing the 7-beep thing even with a known-good cpu.
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      I don't suppose anyone happens to have a BIOS dump from a working Alienware 17 (mid-2013), hmm?
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        On a separate note, there's a chance i might not have an "H_CPUPWRGD" signal. At least i'm reading 0v if i probe right on the empty pad in the XDP header (page 7, top right). There's one tiny trace snaking away from that pad, going to an unpopulated component, but i'm reading 0v on all the pads around that (it's a set of 4).
                        PCH_PWROK, IMVP_PWRGD and SYS_PWROK are all present (3.3v, page 18, bottom left).
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          Have you tried it without the mxm?
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            With it and without it, same story.
                            Still hoping / waiting for a "good" bios dump, or some interesting idea. I've "even" reflowed the PCH a couple times, with no change (for the better or for the worse).
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              Extract original bios, upload it, give your laptop exact model number and service tag to be able to help you.
                              • Khron
                                • Sep 2006
                                • 1350
                                • Finland
                                Extract it... from where, exactly?
                                I'm attaching a zip of the latest BIOS from Dell's site, that i downloaded a few days ago. Right now, for some mysterious reason, that page says "The product you've selected does not have or require updates."
                                Either way, the service tag is 4B6GH12, and the model number is "Alienware 17" ("R1", mid-2013, NOT M17x), came stock with i7-4710MQ and a GTX880M.
                                • atsio
                                  • Oct 2013
                                  • 819
                                  • Greece
                                  we need and the original from uh14
                                  • Khron
                                    • Sep 2006
                                    • 1350
                                    • Finland
                                    Umm... Excuse me, what?
                                    • atsio
                                      • Oct 2013
                                      • 819
                                      • Greece
                                      Read with programmer original bios from UH14 and upload it
                                      • Khron
                                        • Sep 2006
                                        • 1350
                                        • Finland
                                        I just finally got around to doing that. My programmer took about 10mins (635sec) to read the whole 8Mbyte (64Mbit) chip, and it turns out it's EMPTY (checksum 0x0, content's full of FF's).
                                        I most definitely have NOT erased it, although it being empty might very well explain why the laptop didn't do or say anything, when it first came in.
                                        Like i said in my first post, only after i replaced the bios chip (with that dump that i had found), did it start the 7-beep thing.
                                        • tech_guru
                                          Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                                          by tech_guru
                                          Hello.
                                          I am having a disappointing motherboard repair with this laptop and I need your help.
                                          This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                                          -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                                          -PQ102 MDV1525URH
                                          -U17 AOZ1331
                                          -UE1 C8051F383-GQ
                                          -PU800 SY8032ABC
                                          -UI2 SY6288D20AAC
                                          -PU508 RT6220AHGQUF 7P=
                                          -PU100 TPS51225CRUKR
                                          -PU300 TPS51212DSCR
                                          Now, I get all the standby voltages, it turns...
                                          02-16-2024, 09:40 AM
                                        • zwect
                                          Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
                                          by zwect
                                          I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
                                          While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
                                          PCH doesn't seem to be shorted but i haven't done...
                                          12-29-2024, 06:57 PM
                                        • jagiro84
                                          Alienware x15 R2 no memory detected (hell repair job, 6 months later)
                                          by jagiro84
                                          Hi guys,
                                          its been around 5-6months since i left this board on side to rest my brain cells and now came back to try and repair it again.
                                          The laptop in question has issue where it gives error code on power on which is 2red and 3 blue
                                          In short, by Dell specs this means "Memory not detected: "
                                          Now one important thing the laptop would turn on fine when i leave it in the refrigerator for 5-10min and i could work\play games with it for days and months as long as i dont turn it off
                                          but after a while this trick stopped working as wel
                                          12-29-2024, 05:05 AM
                                        • Olixman
                                          Alienware 17 R3 seven beeps
                                          by Olixman
                                          I recently received an Alienware 17 R3. It beeps seven times.
                                          Attached are the schematics and the board view.
                                          I`m stuck at the CPU not getting any voltage. Not getting any PWM at the mosfets.
                                          PU500 outputs a 2.3V (constant, not PWM) on the PWM1_VCORE (and 2 and 3 also).
                                          Replaced it with a new one, same issue.
                                          Any help would be greatly appreciated.
                                          PS.: +3VALW and +5VALW are present.
                                          LE.: Board is an AAP21 LA-C912P Rev:1.0
                                          Schematic ---> https://www.badcaps.net/forum/showth...53132#post9531...
                                          04-21-2023, 02:41 AM
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
