Cleaning newer INTEL motherboards in Ultrasonic cleaner
  • Sushi1808
    • Jun 2014
    • 35
    • Slovenia
    Dear expert community,
    I have read somewhere (forgot the source), that cleaning newer Intel motherboards in Ultrasonic cleaner can sometime cause damage to some components, particularly the PCH.
    What are your experiences regarding this matter?
    I clean all motherboards in Ultrasonic cleaner after BGA rework, since no clean flux residue could develop shorts under BGA after some time. I am talking about fake Amtech 559 flux, bought on ebay. For last few months I only use original Amtech flux from official Amtech distributors.
    I clean all boards in a no name 6L ultrasonic cleaner (without sweeping frequency function), with Electrolube SWAS solution heated to 40C. After every minute of cleaning I take out the motherboard and rotate it, thus the whole exposure time to ultrasonic cleaning is around 4 minutes. After the cleaning, I rinse the boards with warm tap water and after that in a de-ionised water.
    Thus far I had no problems, but I am mainly working with older Intel and AMD laptop motherboards.
    • 31047
    Re: Cleaning newer INTEL motherboards in Ultrasonic cleaner
    afaik the only real issue with ultrasonics is that powerfull ones can damage crystals.
    a place i worked once, we had a tank like a chest freezer!!
    we always cleaned the boards before soldering any crystals.
    i would be more concerned with the choice of solvent used.
    i use IPA now,
    but before it was banned, Freon was the best cleaner.
    • Sushi1808
      • Jun 2014
      • 35
      • Slovenia
      stj thank you for your reply.
      I would use IPA, it is a lot cheaper than Electrolube SWAS, but I cannot since IPA is very flammable and fire safety is a concern. Although, they sell special ultrasonic cleaners, designed for use with flammable liquids.
      I only use IPA when cleaning smaller components, I put it in a 1dcl glass beaker together with the component. It performs well.
      I read somewhere, IPA can be used in a waterproof bag which can be then submerged in the non-flammable ultrasonic cleaning liquid. I thought about using waterproof dry bags from ebay, they are normally used when kayaking and such, to keep stuff dry.
      • alindumitru46
        • Aug 2015
        • 255
        I have a DFI LP UT NF4 SLI DR-EXPERT with pronounced oxidation on the LAN chipset pins and some resistors/capacitors or near 1st PCI-e slot, like here:
        https://onedrive.live.com/redir?resi...nt=photo%2cjpg
        The ultrasonic bay can be a solution to clean?
        I cannot take a Hi resolution photo right now, sorry.
        • Sushi1808
          • Jun 2014
          • 35
          • Slovenia
          Dear alindumitru46 I have no real experience with cleaning the oxidized elements in ultrasonic cleaner...maybe someone else here on forum could be of more help.
          But in my opinion, ultrasonic cleaner is not a magical device...it can't achieve something you wouldn't be able to achieve with a toothbrush, a proper solvent and a bit of manual scrubbing action.
          In your case I would try to remove oxidation with the help of a electrical contact cleaner solution and scrubbing with a toothbrush or similar. After as much oxidation as possible is removed, I would inspect the traces and elements for corrosion under a microscope or magnifying glass, and if everything seems OK, I would try to remove the damaged solder with de-soldering wick and apply a fresh solder.
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            I do agree with you: ultrasonic cleaner is well far from being magical...!
            IPA, or acetone in uglier cases, and manual scrubbing produces far better results.
            On extensive surfaces i also use an air pressure gun (similar to the ones used to paint cars) to proper and faster moisture and debris removal.
            My experience with those waterproof dry bags used in water sports are well bellow expectation.
            They're everything but reliable or waterproof!
            Had quite a few incidents using those while doing water sports and definitely quit using them.
            Instead, you should try using a plastic container (similar to the well known tupperware).
            Beware that the greatest danger arises from the flammable liquid gases due to evaporation over temperature and atomic level agitation,
            not from the flammable liquid itself.
            Therefore, after the ultrasonic exposure, special attention must be taken when removing the plastic container cover!
              • 31047
              put some ice cubes on the cover
              • itsthatidiotagain
                CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
                by itsthatidiotagain
                CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
                There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
                I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
                A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
                06-23-2025, 03:22 AM
              • tricky74
                Chinese no brand ultrasonic cleaner
                by tricky74
                I bought an ultrasonic cleaner from ebay and after a couple of years it blew one of the driver boards fuse and a couple of diodes. I replaced the parts and it worked for a while then died again. Since then I have thrown out the board and just use one. The unit had 2 drivers and the good one drives 1 transducer only. The fried board was driving 2 transducers. The unit works on 1 transducer but is weak in power. I am tempted to connect the 2 transducers that were driven by the dead board. And leave the single disconnected. Not sure if it there is a fault in them and will just kill the driver. As...
                07-01-2022, 06:20 PM
              • diif
                Ultrasonic cleaner but a bit faulty.
                by diif
                After a not very cool noise and the display dimming my ultrasonic cleaner powered off. The display and fan work, just nothing happens when I press the ultrasonic button.
                I think it's at least the triac that is at fault (on the small PCB), showing 57 ohms between pin 1 and 3 and possibly one of the relays (marked in red), I was hoping someone might advise. Thank you....
                09-01-2020, 07:04 PM
              • Evets
                Ultrasonic cleaning
                by Evets
                I've just bought an ultrasonic cleaner and wonder what the fluid of choice is? Isopropyl alcohol was my first thought.
                07-31-2024, 11:33 AM
              • rumi409
                LG OLED C1 Pixel Cleaning Made Picture Worse
                by rumi409
                ​​​​​​ Hi,
                I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                11-15-2024, 01:09 AM
