HP Pro book 4540s - power jack is flashing
  • laptop market
    • Sep 2012
    • 122
    • mansoura
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: HP Pro book 4540s - power jack is flashing
    put a picture for the power connector at the board side. in this case the back side of the board and not the connector itself.
    • alihomee
      • Dec 2012
      • 1594
      • malaysia
      try to post all details of the issue.........like when it start flashing ......after plugin or after pressing power button and also what type of adapter you are using
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
        03-31-2024, 02:12 PM
      • lowpost99@gmail.com
        Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
        by lowpost99@gmail.com
        I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
        09-03-2024, 02:57 PM
