Pavilion G6 High temps
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    So I got this G6 from a customer saying "you can have it". It was used in an auto shop for a diagnostics program
    It's an AMD F1 socket model (A6-4400)
    When I got it, the fan was spinning a lot, I got HW monitor on there and it showed the temps idling at 100 and reaching as high as 125c. Taking it apart, I removed the crappy thermal crud, used arctic silver 5, but not much. Temps were the same. I thought there was a gap so I got a pure copper square and gooped both sides with AS5
    temps dropped but not by much. They maxed out at about 110, but idled at about 80-85c
    voltages show normal, so is this a bad temp sensor? everything else seems to be working ok
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Pavilion G6 High temps
    Can you place your hand near the vent openings for the fan or is it to hot?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      check if other side of heatpipe is hot
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I did clean the little dust out of the sink fins. It was pretty clean. What it blows out is mostly cool-warm air when it revs up
        • rievax_60
          • May 2012
          • 897
          • australia
          Heat pipes do fail. The fluid can leak out.
          • SergeP
            Take heatpipe from your computer. Then warm one end of the pipe with soldering iron, at the same time controlling temperature on the other end of the pipe. If temperature doesn't constantly growing, then you'll need to replace defective pipe.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Interesting I did not know they had heatpipes. I will have to look that one up. so what type of fluid do they usually use for laptops
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                well I warmed one side, my iron is minimum at 350c, the fins reach 300c in a few seconds. So, not sure what the problem is here
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  I think its a gas
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    well hwmon showed it booting at 109C. Its an A4 Mobile AMD APU. Is the temperature sensor on the cpu or motherboard with this one?
                    • subroto
                      • Oct 2015
                      • 230
                      • Bangladesh
                      Is there discrete graphics with the mobo?
                      If has then it might be the culprit. If not then the heat sink copper tube.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        no graphics, all on the APU
                        I said above I heated the copper sink with my iron and used my temp gun and it transferred the heat pretty fast, so I think its good. Looks like a bad temp sensor to me, but not sure I should replace the CPU or motherboard
                        • subroto
                          • Oct 2015
                          • 230
                          • Bangladesh
                          Then try replacing the APU.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            I'm thinking of changing out this A6 for an A8 quad core. Same die, tdp, socket. Effectively making the g6 a g7. Should be ok? Ive done it before with old core 2 based pdcs to full core 2
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              You most likely have check this, but I remember on some HP they have a setting in the bios for the fan. Turning it on active.
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                Yeah it was turned on
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  I wonder then if the temperature sensor is not turning on the fan quickly enough? Or is the fan running all the time and the temperature stays hot?
                                  Again most likely you checked these things, but you never know when someone forgets.
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    no fan stays on all the time, boots hot. Got the A8, didn't expect the die size to be bigger, and it boots "hotter" (130C). I say put it in quotes because i'm pretty sure the thermocouple on the motherboard is bad and its not actually 130C. So I have to get a motherboard. Not cheap, well not too bad for this laptop
                                    i'm just tempted to cut my losses if the board is too much. I have a barely used lenovo with a i3 and busted screen. Might just get a new screen and an Dell PA -> Lenovo plug adapter (this is a lenovo with one of those wierd shaped adapters, but dual rail and can take a PA-12 just fine)
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      Have you informed HP as this might be a design problem.
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        I just googled and it seems to be a known problem. Too bad, even if it was within warranty, I already voided the warranty by taking it completely apart. It is a bad thermocouple.
                                        oh and I was wrong the lenovo wasn't an i3, but an A10 elite quad core. barely even used
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP Pavilion Pavilion Desktop - 570-p035t Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p035t can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p035t boardview and Pavilion Pavilion Desktop - 570-p035t schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:36 PM
