R4 Remote pairing led keeps flashing
  • ivtec
    • Dec 2008
    • 1967
    HI GUYS:My Roku 4 Remote Control doesn't work at all,it doesn't pairs, the pairing green light keeps flashing all the time,
    it worked for while but started to eat batteries every 4 days or less,and now green pairing light keeps blinking,what a piece of crap remote,
    the Roku 4 receiver is work great ,no issues lately, i use Roku 1 remote control which works great with it.
    • 30963
    Re: R4 Remote pairing led keeps flashing
    "pairing" ??
    is it bluetooth? i thought they used regular infra-red.
    • ivtec
      • Dec 2008
      • 1967
      Originally posted by stj
      "pairing" ??
      Thanks ,No it's infrared.
      • Mc_Millian
        Toshiba 50lf711u20 fire tv remote not pairing
        by Mc_Millian
        I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
        The Tv model number is: 50lf711u20 Rev B.
        I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
        I've tried 3 different remotes which should be fully compatible with this TV.
        Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
        The power button, along with the volume,back,select, and directional...
        04-07-2022, 12:15 PM
      • STKR123
        Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
        by STKR123
        As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
        I wonder if re-flashing the BIOS might be of any use here.
        As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
        There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
        11-03-2024, 06:58 AM
      • cstout
        DeLonghi AC Remote only accepts 3V
        by cstout
        Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
        The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
        I can't find any schematics...
        06-03-2024, 03:53 PM
      • edugimeno
        HiSense 55A7500F won't obbey to remote after power on
        by edugimeno
        Hi! I have this TV set that does the following:
        1) I press the red power button on the remote
        2) The TV turns on normally
        3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
        4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
        Then after it's off, it would again accept the TURN ON from the remote and same again
        BUT:
        -The remote does show the correct IR beam while observed thru a phone camera
        -The TV works fine while using the MiRemote...
        03-14-2023, 11:22 AM
      • tmhobadcap
        Pioneer VSX-522-K remote control not working???
        by tmhobadcap
        I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
        At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
        12-24-2020, 01:44 AM
