HP Pavillon 17-f166nf boot loop
+ More Options
Posts
  • piernov
    • Jan 2016
    • 4435
    • France
    As you can see on this video : https://youtu.be/XDtxhd0UFYM ; I have an HP Pavillon 17-f166nf which does not want to turn on.
    After pressing power button, power LED turns on and fan starts to spin for a second, then it powers off, then again LED turns on and fan starts to spin.
    Corrupt BIOS? Reflow needed? Something else?
    I measure only 22 ohm on some caps under GPU. Is it dead?
    Some caps under CPU shows around 70 ohm but I think it's alright.
    Attached are some photos of the board, original BIOS backup, and schematics (may not be exactly the same but close enough).
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: HP Pavillon 17-f166nf boot loop
    Seem bios problem
    • piernov
      • Jan 2016
      • 4435
      • France
      Do you have a dump for this one?
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        flasher avec ce fichier
        • piernov
          • Jan 2016
          • 4435
          • France
          Thanks but it still doesn't work… Nothing changed with your ROM.
          • piernov
            • Jan 2016
            • 4435
            • France
            Tried to remove PL12, PL13, then removed GPU as I was suspecting it. Nothing changed.
            Removed PL14 just to see what would happen, and nothing changed either.
            I've no other idea. Could it be a dead CPU/PCH? How can I test it? Anything else I can try?
            • toufik sat
              • Feb 2016
              • 134
              • los angles
              Thank you so much work for me
              • Nasir Raja
                • Mar 2014
                • 21
                Thanks I just download i will get back to you with updates mate thanks for sharing
                • nasnus123
                  • Jan 2016
                  • 28
                  • india
                  Thanks its worked for me .
                  But power on message is" Manufacture Programming Mode is in Unlock mode"
                  and invalid Board sn/ model
                  • raihan
                    • Feb 2016
                    • 41
                    • Bangladesh
                    Need uma bios
                    • Foul
                      • Nov 2024
                      • France
                      Working with 0227D.bin
                      thx !
                      • Takeatry
                        Yet another Samsung QLED Boot Loop
                        by Takeatry
                        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                        10-04-2024, 02:57 PM
                      • blaster_
                        Samsung UE49MU6105K - boot loop, horizontal lines
                        by blaster_
                        Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                        Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                        06-22-2022, 05:19 PM
                      • torchzack
                        Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                        by torchzack
                        Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                        I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                        Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                        08-28-2023, 07:42 AM
                      • trbovan
                        Asus GL731GT Boot loop
                        by trbovan
                        Laptop is a GL731GT with the I7-9750h and GTX1650.
                        Full model number is gl731gt-rb71-cb
                        Serial: (placeholder for when I get home)
                        Board model: G531GT REV. 1.5
                        Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
                        I assembled and tested anyway. The bios worked, I was able...
                        10-04-2023, 07:27 AM
                      • abajor
                        Alienware Area-51 R2 Boot Loop issue.
                        by abajor
                        I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
                        It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
                        To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
                        Right now I'm trying to dig through the PDF schematics and Board...
                        03-08-2024, 10:08 PM
