7740G (JV70-CP MB 09293-1) DEAD - NO LIGHT - NO START - NO SOUND - U82 already change
  • User013597
    • Feb 2016
    • GE
    Hello.
    I made a own post, because i think its not the same like the other one about 7740g. I hope you can help me.
    One day i shut down my Acer 7740G (JV70-CP MB 09293-1), but after a very short time it was off. The next day i tryed to start up nothing happend...
    There was no lights on when i put the charging cable (only the light at the cable was on) inside. After pressing power there was no light, no sounds, nothing (the charging cable light was still on while pressing).
    Now after a long time i tryed to repair it. So i had some help and dismounted everything.
    After this i was looking for the power supply socket but we could messure the 19V behind the power supply socket. There was allthough power at the charging battery cells.
    After a long time i found out that i could be the U82 TPS51123. There was a problem with 5v and 3.3v because i just found some spots arround U82 with 3.3V. After i managed to get the U82 TPS51123 changed by a professional stuff. After this we checked if there is light on the mainboard if we put the charging cable into the mainboard, but there was no light on, nothing changed, after pressing power button alltough nothing. We can not find 5V or 3.3V at L35 or L36 and allthough we only found at one Testpoint arround U82 (i think it was TP59 or TP69) a volltage.
    Maybe if this is important: 1 Year after i boght this notebook the DVD / Blueray player stoped working (its working on 5V). And i had some problem with the temperatur inside (maybe there is a known problem cause of this heat). But after 1-2 month checking the fan i noticed that the louver were full of dust.... But after removeing the dust the notebook was working fine like 1 year.
    So now i hope you know what to do and please tell me step by step what to do.
    Have a nice day.
  • spads
    • Aug 2016
    • GREECE
    Re: 7740G (JV70-CP MB 09293-1) DEAD - NO LIGHT - NO START - NO SOUND - U82 already ch
    reprogram kbc ic
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • esqmooo
      HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
      by esqmooo
      Hello everyone.
      This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
      Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
      Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
      I tried long pressing on the power button, after several seconds it would go off then when the button is released...
      03-11-2025, 03:57 PM
    • MOSSEP
      Monitor Audio RSW12 - Green light, but no sound
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:33 AM
    • Patan
      Dead LA-H323P (no light) - HP 15-DW
      by Patan
      Need help here...
      I'm new on the forum and I'm not professional in electronics so i ask sorry in advance for eventual errors...
      As title says, i have a LA-H323P dead.
      Now, little background.
      The computer was working fine, just seems that the cable of screen was dying because it had the classic color problem, sometimes green, sometimes violet, sometimes perfect, but anyway working.
      When i opened it the battery was so fat that was seriously near to explode.​
      So i removed the battery... and turned on the notebook... that was, again, working perfectly fine....
      04-28-2024, 03:31 AM
    • Rav_tangle
      MacBook Pro 2011 turns on with keyboard light , screen dead
      by Rav_tangle
      Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
      I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
      Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
      is this...
      05-31-2024, 04:09 PM
