Short to ground
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Short to ground
    This laptop I received recently and its short to ground (DAOZE6MB6E0)
    once pq 116 removed short with pq 33 was vanished.
    but pq 35 pin 1 2 3 short to ground 4 5 6 7 8 is ok please tell any expert how to find it .
    sigpic
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: Short to ground
    below component removed and checked but still short remains.
    pc 79 ,pc 80, pr 6, pr 7, pq 34 , pq 43 , pq 2 , pu 7.
    sigpic
    • rievax_60
      • May 2012
      • 897
      • australia
      Re: Short to ground
      I have been using a method explained here starting at post #25, https://www.badcaps.net/forum/showth...t=46808&page=2
      I find shorted capacitors quickly if it is a faulty capacitor.
      You need to have a multimeter with 10uv resolution for this method to work and understand the relationship between voltage, current and resistance.
      Whatever you do or are told to do, do not apply more than 1 volt from an external supply.
      EXTRA: Maybe there is a capacitor that isn't shown on the schematic.
      • rievax_60
        • May 2012
        • 897
        • australia
        Re: Short to ground
        Have you tried removing PR116 to narrow down the area of where the short is likely to be?
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          Re: Short to ground
          Thanks for replying . yes I tried..what I mentioned above is a mistake .pq 116 should be pr 116. no luck, I will try as you said and let you know. Thanks for your time.
          sigpic
          • samanthban
            • Feb 2014
            • 253
            • Sri lanka
            Re: Short to ground
            Thanks bro , got my ignition from your link and found the culprit . its pc 126 .Nearly 15 component were removed . I need proper multimeter for relevant method .without that it can do little bit hard .
            sigpic
            • rievax_60
              • May 2012
              • 897
              • australia
              Re: Short to ground
              There is more detail here, https://www.badcaps.net/forum/showthread.php?t=35231
              Post #9 is important to understand.
              • samanthban
                • Feb 2014
                • 253
                • Sri lanka
                Re: Short to ground
                Thanks for your help
                sigpic
                • playit
                  450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                  by playit
                  hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                  09-02-2023, 02:43 AM
                • MisterAIL
                  820-00840 / No boot / PP3V3_G3H Short to ground
                  by MisterAIL
                  Firstly sorry for my english, french guy inside.
                  I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
                  History is a day, nothing happened when opening the laptop.
                  Nothing special inside, no corrosion, no liquid damage, never opened.
                  First, with the logicboard alone on the desk, mesures are :
                  5v017 and 0.000 amp. nothing else.
                  Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
                  10-13-2021, 11:42 AM
                • triplefour
                  Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                  by triplefour
                  Samsung UN55ES7003
                  made house call.
                  red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                  psu has self test feature.
                  disconnected from mainboard.
                  determined PSU ok BL ok.
                  suspect mainboard.
                  disconnecting tcon has no change on operation.
                  markings on mainboard:
                  BN97-06531P 0151
                  BN94-06123R
                  found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                  for 54$
                  second house call:
                  with replacement mainboard, tv turns on, has sound,...
                  07-13-2022, 03:53 PM
                • Prott
                  PS5 - long screw damage, via to ground layer short?
                  by Prott
                  Hello dear Badcappers,
                  I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
                  Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
                  07-27-2024, 08:54 AM
                • DynaxSC
                  Extreme High Current & Low Voltage Short Killer ??
                  by DynaxSC
                  Hi Folks
                  I'm looking for a extreme high current short killer solution for a reasonable cost.
                  I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                  After taking off the socket, the shorts dissappear again.
                  The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                  10-15-2024, 10:13 AM
