kindle Charger port.
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;first of all i'm happy that Badcaps is back up again and stronger, thanks;Now i'm Bringing up the Missing traces Charging port issue, and admitting that i failed completely on soldering it to the board due most and for most poor Vision,i wasted 3 ports,cause i have to admit that i'm damn stubborn and i never give up,even if that costs me money,
    Now i took another way in order to salvage the kindle,at least to make it work,
    so i grabbed a USB cable and connected it to power supply and striped one end and checked for the 5 v wires so i got 5v on black +brown wire and cut off the remaining wires then i soldered the 5v wires strait to the board to the 1 and 5 traces or the traces on the outside,
    now Kindle is working great but i have to plug in power supply in order for it to turn on in, that's ok and it's better than nothing or trash it.
    Now i just want your expertise on this circuit,connecting the 5 v this way to the motherboard! is it getting power from the power supply strait to the the motherboard or does it go to the battery then motherboard?,it does turn off the screen after being not in use for some time or unplugged
    http://www.ebay.com/itm/Kindle-Fire....8AAOSw8-tWXglW
    • 31013
    Re: kindle Charger port.
    your port has nothing to do with this, it's a seperate problem.
    either your battery is toast, or the charging is faulty.
    meter the voltage at the battery connection with and without the usb conected - see if it tries to charge.
    • ivtec
      • Dec 2008
      • 1967
      Thanks stj; it's charging all right,the only issue,it wont turn on if i do not plug in charger,if battery is charged enough i can unplug charger and use it,
        • 31013
        so the battery is not supplying the power switching circuit - probaby something small like a diode or resistor missing / bad
        • ivtec
          • Dec 2008
          • 1967
          Maybe but it's working find this way,it's for my grand-kid to play with it, so it's find till i get her a new one for her birthday,i intend to get her this
          http://www.staples.com/Samsung-Galax...nalize=certona
          • ivtec
            • Dec 2008
            • 1967
            Hi stj and thanks for Bad-caps coming back stronger,.
            now i was satisfied with the way this kindle was working but it's back to being dead after i tried to tuck up the charger wire that part of it came off,i used Glue to hold cable inside,but the damn epoxy glue did not glue the cable and was hanging out,so i opened it up and tried to secure firm inside i did not do anything,just made an opening to pass it through,i put it together and it did go dead, ho well i gave it a shot,i guess i got to get another one,
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • Johndill
              Dell Inspiron 7567 LA-D993P odd charger issue
              by Johndill
              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
              Here are the tested scenarios:
              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
              2. With the laptop off, plug in charger (LED says on) & the front charging...
              11-16-2022, 10:55 PM
              ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
              Highly Integrated Narrow VDC Battery Charger for Notebook Computers
              The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
              for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
              Narrow VDC applications where the system power source is
              either the battery pack or the regulated output of the charger.
              This makes the max voltage to the system equal to the max
              battery voltage instead of the max adapter voltage. Operating
              at lower system voltage can improve...
              11-05-2024, 04:43 PM
