Dell inspiron 15 shorting out charger (la-9104p) keeps blowing mosfet
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: Dell inspiron 15 shorting out charger (la-9104p) keeps blowing mosfet
    Originally posted by meritosari
    -Pq100 & PQ101 (ac_fet), if one of them shorted then that indicate there's have problems with B+ (19v)or to much high current flow with it. a bit experience, also could be followed with other components has shorted.
    could be bad caps, mosfets or ic chips.
    -B+ spread to dc/dc 3.3v/5v, also to high side mosfet each dc/dc's, and reach to connector ldvs
    -make sure before do replacement, the short circuit on B+ has gone, you can check resistance versus ground on the empty pad after you had removed components
    -if want to inject with psu, not over than 1v . except you know there's no high side mosfets dc/dc has shorted. a little trick, if you want to increase voltage psu, while that do measure on coil cpu core, 1.05v (that has just low volatages). if you've find voltage on a coil, so high side mosfet has shorted.
    -you see on schematic. 19v transform to other name vin>>>>p2>>>>>p3>>>>>B+>>>>>CHG_B+ and B++ to rt8205, whereas same 19v
    -at last, check Batt+ not shorted to ground
    Thanks for the reply Meritosari .
    removed PQ101 pin 5678 have 0.6 ohm shorted with ground, Pin 123 19.8V pin4 8,44V.
    injected voltage with Psu 1v 8a but any component does not heat up. and on coil cpu have 5.9ohms and no voltage 0V.
    Batt+ measured on PR121 are shorted with ground.
    Any other help please
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      Originally posted by tibd
      Had same problem once on one of boards, turned to be pc502 in the circuitry of pq500. then the problem returned after a week later, the issue then was at the same circuitry but this time pc501. Ended changing all those four caps, device never returned back to me, may be to someone else!!
      THANKS TIBD THANKS , SOLVED
      PC502 burned replaced ok ALL FUNCTION
      no more short on B+.
      How you find it with PSU lab ?
      • tibd
        • Oct 2014
        • 189
        • Sweden
        yes with PSU. I would recommend you change all those 4 caps, and preferably with at least 35 v rating, higher would be better.
        • Mr repair
          • Aug 2013
          • 10
          • usa
          Originally posted by Blacktek
          thanks my friend but no luck, still same problem.
          I removed the shorted pq101 and replaced it with a ao4407,then removed the pl100. reconnected to laptop but it shorted out pq101 for the 5th time..
          check and see if you are installing the mosfet the right way
          • Nikosz
            • Nov 2013
            • 27
            • Out Of Space
            i have 2 motherboards with exactly the same problem.
            has anyone found any solution?
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • Johndill
              Dell Inspiron 7567 LA-D993P odd charger issue
              by Johndill
              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
              Here are the tested scenarios:
              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
              2. With the laptop off, plug in charger (LED says on) & the front charging...
              11-16-2022, 10:55 PM
