vpceg28fg (pcg-61911w)
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    Hi
    the customer brougth this laptop sony pcg-61911w with no usb
    he said that he was charging his phone thru the usb of the laptop, then all usb won't work again
    when inserting a hard drive, only the led comes on. i formated the laptop with no success
    where i should start
    can someone help??
    thanks
  • dj_ricoh
    • 2073
    • uk
    Re: vpceg28fg (pcg-61911w)
    those models comes with usb that gone ribbons that goes to USB.
    try to replace it or unhook it and see if the internal usb from the board works.
    what`s missing the 5v or there is no data trow the wires?
    • mazloum
      • Sep 2012
      • 504
      • Lebanon
      i tried it with no success
      the 5volts are present , but no data
      • zomi
        Manual cof bonding success rate ?/ feedback wanted
        by zomi
        Just wanted to get some feedback,
        whats peoples' success rate with cof bonding repairs.....
        09-23-2024, 12:45 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • valvashon
        Repair Success! Middle Atlantic UPS2200R-IP
        by valvashon
        Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
        Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
        02-06-2024, 12:54 PM
      • Valtekken
        Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
        by Valtekken
        Specs:
        • CPU=AMD Ryzen 5 3500U
        • GPU=(integrated) Radeon Vega Mobile
        • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
        • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
        Hello everyone.
        My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
        A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
        09-10-2025, 04:14 PM
      • chromecut
        NVME support for Lenovo Insyde laptop B40-30 (circa2014)
        by chromecut
        I need some guidance-any logical sense of this would be mighty appreciated
        I usually prefer to do the work myself but to0 many impossible projects calling my name-Im having trouble getting nvme support for this lenovo insyde biios laptop B40-30-any moddying=brick-Ive unlocked all the register with direct hex edit to signed bios which didnt break the bios amazingly, signed the oem flashing tool and the bios (fptw allows full dump but no write back)to what I thought was success: no warnings fully flashed and then=brick
        I cant try the sleep bug trick as I need 9ccn30ww.exe which somebody...
        04-19-2023, 06:57 PM
