Dell XPS M1330 Intel platform- NO EN signal for 3/5V ALW what is wrong?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Hello have this dell XPS M1330 that have no EN signal for 3/5V ALW TPS51120 IC. What signals/voltages must have to SIO release this signal?
    flashed bios but nothing changed
    i have 3.3LDO from TPS51120 and 3.3V from battery and rtc
  • khaahk
    • Dec 2013
    • 755
    • Estonia
    Re: Dell XPS M1330 Intel platform- NO EN signal for 3/5V ALW what is wrong?
    Maybe after power button is pressed? Do you have 15V alw?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      when have no 3.3Valw, no pover for power button
      • khaahk
        • Dec 2013
        • 755
        • Estonia
        The power button seems to be pulled high by rtc_cell, this should be present.
        Check the +15V_ALWP, it might need to be present to turn on other rails. Does Q68 get 32kHz signal to gate from SIO? It might be generating the pulses to make 15V...
        Just guessing here...
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Jeff'sTech
          Dell Latitude 7420 BIOS Unlock Gone Wrong
          by Jeff'sTech
          Hello everyone.
          I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
          11-08-2023, 03:30 PM
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • glutton4punishment
          Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
          by glutton4punishment
          Samsung synchmaster 226BW.
          Before I replaced 5 caps, the screen was dim.
          Sometimes it wouldn't turn on.
          I opened it up, and found 4 bad caps in the pwr supply section.
          I unfortunately installee one backwards, i.e. wrong polarity.
          When I turned it on, I head a loud pop, and I quickly shut it off.
          The replaced caps are 3 860uF 25V's, and 1 330u 35V.
          One of the 860uF blew.
          I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
          03-18-2023, 12:49 PM
        • Loli Popu
          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 03:28 AM
