Have a dead short on the DCBATOUT side of this board. PU4308 became very hot when I applied current to dcbatout pad of PR4002. Removed 4308 (p. 43), short gone, but pins 1-3 on board still short. Removed PL4303 and pins of PU4308 no longer short. So also removed PL4302 and 4303. VCC Core side of all 3 coils are short. Put current to one of the pads, shows short for sure but can't find smoking gun. Is it one of the caps (ST330U2V, 6 in all) right after the coils? Or one of the caps on page 8 (left hand side of page)? Am I on the right track?
Dell N5050 dead short
Tags: None
Re: Dell N5050 dead short
Turned out to be one of the large black caps, ST330U2V, PT4308 I think. Short completely gone. Replaced with one off a scrap board, soldered everything back on and board shorted again as soon as plugged in. Removed all 6 caps again but this time in different order and the one I removed last eliminated the short. But it wasn't 4308 this time. Is there something I should know about replacing these caps that I'm missing? Coincidence both times that last cap removed eliminated the short? Because I checked for short after removing 1 cap at a time... -
Yes, PU4308 was dead too. None of the caps measure short after removing from the board. Can I replace PU4308 and try to plug in the board without those 6 caps just to verify they're the problem? Probably not a good idea if they're not. I've got a DC power supply too, maybe I can slowly raise the voltage? Not sure how to proceed, just know I want to eliminate those caps as the problem.Comment
Plugged board in with no caps, no short! Even got a blinking power light and have 3v and 5v at coils. Will go no further until I can figure out this cap issue. Used hot air to remove and install, is that a no-no for this type?Comment
It is all a puzzle. Capacitors of any type usually don't become good again after going short.
Judging by what I have seen others do, these capacitors tolerate a lot of heating. People including myself used to get misled into thinking a short was present because of the normal 4 to 6 ohms of the CPU. An I5 CPU I measured lately seemed to be over 100 ohms.
How do you define a short?
I can't find a full data PDF for the controller IC. Most of them have crowbar protection where the low side MOSFETs are turned on to keep Vcore clamped when certain faults occur that try to make Vcore too high.But this will not show as a short while all inductors
are removed.
There can also be a pin on the IC connected directly to the Vcore that is able to clamp to ground. So you might measure a few ohms to ground which can remain long after power is removed. Before you know it, the short is gone.
The shorted high side MOSFET is likely to have been the only fault.Last edited by rievax_60; 11-21-2015, 02:32 PM.Comment
I installed a CPU, plugged the board in and it shorted again, blowing PU4308. Removed PU4308 and PL4303. VCC Core side pad of PL4303 measures about 1 ohm to ground. With my power supply set to 1 volt and 2 amps on that pad, I measure 1 volt and about 1.65 amps. I know a dead short would show no voltage and 2 amps and no problem would show 2 volts and 0 amps. So what is my power supply showing me?Last edited by p1muserfan; 12-13-2015, 08:53 PM.Comment
Found it, it was PU4307, replaced, so now I'm back to having 3,5v power to the board with nothing installed. With no power to the board and no CPU installed, I'm measuring pretty high resistance to ground on the 3 CPU power coils. With a CPU installed I measure about 16 ohms, which I understand to be about right. So is my chipset ok? Hate to keep installing a CPU and having the board short every time I plug it in, is there something else I can check?Comment
What I call Vcore, is called VCC_CORE in the schematic. I had trouble lately with a Lenovo.
The Vcore was going to 6v because of a fake ADP3212 controller IC I put in. It made the I5 CPU go short circuit. The Lenovo would turn on the Vcore rail without the CPU fitted. I caught the rail going to 6v for a short time before shutting down with a DSO.
As a precaution I rats nested a crowbar protector that I soldered across the Vcore rail that was set to trip at 1.5v.
When I fitted a good ADP3212, new MOSFETs and CPU, it all just worked, the crowbar did not need to trip.
I cant see any other safe way to test it. Ill say more if I think of something.Comment
Still in need of some help here. Have standby voltage and white power light on an empty board (no CPU or memory installed) only because PT4301,2,3,4,8 and 9 are removed. If they're installed, board shorts immediately. Why? Because I measure 19v across PL4301,2 and 3. Isn't that voltage only suppose to go as far as the upper fets (PU4302,5, and 8)? This can't be goodComment
by Geeker007Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
I am new to electronics repair, so my queries could be naive but I am ready to learn.
So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is... -
by retrorepair2Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...1 Photo -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by gugutmhi everyone,
need some advice i am not professional just junior , but maybe someone could help me please
i have
Device : Laptop
Brand : DELL
Model : LATITUDE 5410
Board Number: FDZ41 LA-J371P Rev:1.0
i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
my problem is its not turning... -
by Francesc V.Hi:
A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
Here are the findings, followed by good pictures. :-)
When pluged in, LED3 glows
Measuring some voltage in the circuit.
Inductors
- PL202 has 5V
- PL201 has 3.3V
- PL300 has 1V
V. Regulators
- UT30 has 19v as input and 6V as output. It seems ok.
- UT27 (same reference as UT30, has no input/output voltage).
Thermal find...07-09-2025, 12:12 AM - Loading...
