HP laptop with no power. Can you help me understand the DA0R75MB6C1 schematics?
Re: HP laptop with no power. Can you help me understand the shematics?
You said it had a shorted USB port. What exactly did youy remove? I would start with the USB driver chip. The easiest way to find shorts is with a thermal imager but that's not something many people have access to.Comment
Speaking of thermal, I can feel warmth from the area with the 3v and 5v chips. I will explore some more.Comment
Page 29 "LAN conn & Right SIDE USBX1"
If I pull PL20 and PL21 from the board, would I be able to isolate the short to one side of the inductor or the other?Comment
Yes you would but I doubt its on the regulator side.Comment
USB_PO+ and - from that USB port go to the chip on page 6.
If the port was crushed there may have been a short from 5VS5 to ground and /or to the USB data lines.
If it was me I would probably remove the PL20 / PL21 inductors and apply a voltage directly to were the 5V are supposed to be, with current limit starting from 0A slowly increasing. If there is short in a component that component will heat up.
Trying to isolate the short by cutting traces would be too cumbersome.Last edited by paulstef; 11-20-2015, 08:34 AM.Comment
Trying to isolate the short by cutting traces would be too cumbersome.Comment
EN comes from the chip on page 33 which needs +3V at VCC to work, I can't seem to find where this comes from...Comment
yes that's for VCC. try to find where that comes from. but you still have a short on the output of those chips...
not exactly the easiest board for a first time component level repair :-)Comment
PL20 is currently open to ground because I removed and reattached the power IC and probably didn't get all legs connected.
So maybe it's not as tough of a case as it appeared to be. Bench top power supply is in the mail so hopefully I can crack this egg soon.Last edited by mattpd; 11-21-2015, 03:29 PM.Comment
Injected 5v 1A into the system side of the 5V line and the ISL6277A chip got uncomfortably hot. It doesn't look like that chip is for sale anywhere tough. Is this the end of the road?Comment
Maybe it's not that chip but something on the outputs? I would check all outputs for shorts to GND first.
See page 3 here:http://www.intersil.com/content/dam/...6/isl6277a.pdf
to identify them.
Test UGATE, PHASE, LGATE and PWM outputs.
The MOSFETs being driven are on the next page in your schematic (p39). Check them out too.Comment
http://www.aliexpress.com/item/ISL62...rchweb201560_1Comment
Excuse my ignorance, but how can I go about checking the output for shorts? My only guess is to remove the chip and check resistance from the output pads to ground. Would that work?Comment
to identify them.
Pin 18 to ground = 2.5ohm
Pin 19 to ground = 2.5ohm
Pin 26 to ground = 15ohm
Pin 32 to ground = 0.5ohm
Pin 35 to ground = 1.5ohm
Pin 45 to ground = 11ohm
Removing FETs next to test them...
FETs removed:
On PQ3, PQ4, and PQ6 resistance between S and D is open, until touching the gate with red probe and then 0.5ohm between S and D (seems normal to me).
PQ7 the resistance between S and D is 160ohm until touching gate and then 0.5ohm.
So it seems like as though PQ7 is working (opening and closing) but it has a much lower resistance between S and D than PQ6 (which is the same part number). PQ7 must be bad, right?Last edited by mattpd; 12-09-2015, 11:14 AM.Comment
This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 06:00 PM
This specification for the HP ProBook 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook x360 830 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 830 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-06-2024, 12:00 PM
This specification for the HP EliteBook 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 12:00 PM
- Loading...
