HP laptop with no power. Can you help me understand the DA0R75MB6C1 schematics?
  • mattpd
    • Oct 2012
    • 302
    Re: HP laptop with no power. Can you help me understand the shematics?
    Originally posted by paulstef
    You measure after PL20 and PL21 to ground, not directly from the chip to ground. Even though it wouldn't matter much if the inductor is ok because of its low DC resistance...
    I get 0 ohms measuring PL20 and PL21 to ground. How would I go about finding what is shorted?
    • paulstef
      • Dec 2013
      • 724
      You said it had a shorted USB port. What exactly did youy remove? I would start with the USB driver chip. The easiest way to find shorts is with a thermal imager but that's not something many people have access to.
      • mattpd
        • Oct 2012
        • 302
        One of the auxiliary USB ports was crushed and shorted. I just disconnected that board. It wasn't one of the USB ports on the main board. Not sure if it is related or not.
        Speaking of thermal, I can feel warmth from the area with the 3v and 5v chips. I will explore some more.
        • paulstef
          • Dec 2013
          • 724
          Can you identify that board you removed on the schematic?
          • mattpd
            • Oct 2012
            • 302
            Page 29 "LAN conn & Right SIDE USBX1"
            If I pull PL20 and PL21 from the board, would I be able to isolate the short to one side of the inductor or the other?
            • paulstef
              • Dec 2013
              • 724
              Yes you would but I doubt its on the regulator side.
              • paulstef
                • Dec 2013
                • 724
                USB_PO+ and - from that USB port go to the chip on page 6.
                If the port was crushed there may have been a short from 5VS5 to ground and /or to the USB data lines.
                If it was me I would probably remove the PL20 / PL21 inductors and apply a voltage directly to were the 5V are supposed to be, with current limit starting from 0A slowly increasing. If there is short in a component that component will heat up.
                Trying to isolate the short by cutting traces would be too cumbersome.
                • paulstef
                  • Dec 2013
                  • 724
                  Alternatively, if there is anything else you could remove from the mainboard I would do that first. Modules, ICs, everything, leave only the mainboard and DC power.
                  • mattpd
                    • Oct 2012
                    • 302
                    Time to invest in a bench power supply then.
                    • mattpd
                      • Oct 2012
                      • 302
                      Yes
                      I was able to confirm today that there is no EN voltage on either chip. It seems that the short circuit is causing "S5_ON" to not be present.
                      • paulstef
                        • Dec 2013
                        • 724
                        EN comes from the chip on page 33 which needs +3V at VCC to work, I can't seem to find where this comes from...
                        • mattpd
                          • Oct 2012
                          • 302
                          That's pin 11 for VCC, right? I am getting 0v.
                          • paulstef
                            • Dec 2013
                            • 724
                            yes that's for VCC. try to find where that comes from. but you still have a short on the output of those chips...
                            not exactly the easiest board for a first time component level repair :-)
                            • mattpd
                              • Oct 2012
                              • 302
                              The meter I was using was complete shit, so I think I may have been mistaken about the shorts to ground on the outputs, at least on PL21. It is 2.5ohms to ground.
                              PL20 is currently open to ground because I removed and reattached the power IC and probably didn't get all legs connected.
                              So maybe it's not as tough of a case as it appeared to be. Bench top power supply is in the mail so hopefully I can crack this egg soon.
                              • mattpd
                                • Oct 2012
                                • 302
                                Injected 5v 1A into the system side of the 5V line and the ISL6277A chip got uncomfortably hot. It doesn't look like that chip is for sale anywhere tough. Is this the end of the road?
                                • paulstef
                                  • Dec 2013
                                  • 724
                                  Maybe it's not that chip but something on the outputs? I would check all outputs for shorts to GND first.
                                  See page 3 here:http://www.intersil.com/content/dam/...6/isl6277a.pdf
                                  to identify them.
                                  Test UGATE, PHASE, LGATE and PWM outputs.
                                  The MOSFETs being driven are on the next page in your schematic (p39). Check them out too.
                                  • paulstef
                                    • Dec 2013
                                    • 724
                                    http://www.aliexpress.com/item/ISL62...rchweb201560_1
                                    • mattpd
                                      • Oct 2012
                                      • 302
                                      Thanks for the link. I have one on order just in case it is the chip.
                                      Excuse my ignorance, but how can I go about checking the output for shorts? My only guess is to remove the chip and check resistance from the output pads to ground. Would that work?
                                      • mattpd
                                        • Oct 2012
                                        • 302
                                        to identify them.
                                        ISL6277A removed
                                        Pin 18 to ground = 2.5ohm
                                        Pin 19 to ground = 2.5ohm
                                        Pin 26 to ground = 15ohm
                                        Pin 32 to ground = 0.5ohm
                                        Pin 35 to ground = 1.5ohm
                                        Pin 45 to ground = 11ohm
                                        Removing FETs next to test them...
                                        FETs removed:
                                        On PQ3, PQ4, and PQ6 resistance between S and D is open, until touching the gate with red probe and then 0.5ohm between S and D (seems normal to me).
                                        PQ7 the resistance between S and D is 160ohm until touching gate and then 0.5ohm.
                                        So it seems like as though PQ7 is working (opening and closing) but it has a much lower resistance between S and D than PQ6 (which is the same part number). PQ7 must be bad, right?
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #40
                                          Try testing the FETs using the diode function on your multimeter.
