Lenovo G500S vilg1/g2 LA9901P battery related problem
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 343
    • India
    Hi!
    Laptop works fine with adapter power, without battery.
    As soon as I connect battery ,if it has power ,PU401 starts heating
    until o disconnect battery .already replaced pu401 (which was defective)
    what is to be checked.
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 343
    • India
    Re: Lenovo G500S vilg1/g2 LA9901P battery related problem
    No one no ideas ...
    • polytek
      • Dec 2013
      • 496
      • TUNISIA
      first :check PQ312 (AO4407AL) for short and if it get hot
      then check the charger ic PU301 BQ24727RGRR pin 10 ILIM pin 1 of pr315=3.3V
      if less change PU301.
      • 1HandyDud
        • May 2018
        • 5
        It seems to be common failure with this platform. I am fixing one now, and it has PU401 blown as well as PL401 destroyed, U39 looking good but suspected faulty or floppy... so keep fingers crossed and parts on the order.
        • tomodachi
          • Apr 2012
          • 600
          • Turkey
          PU401 produces +3VLP which is also called AUX power for various devices on that platform (audio ic, network ic, Vcrore IC for some platforms, also PCH) See if there is anything shorted on that voltage rail first othervise you will fry new PU401 IC too, good luck
          • ferah831208
            by ferah831208
            03-18-2025, 01:18 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • code share
            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
            by code share
            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
            Here's what I've tried so far:
            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
            • Booted successfully on AC power only with the battery disconnected
            • Visual inspection of the battery — no swelling, burn marks, or connector damage
            • Battery
            04-21-2025, 12:50 PM
          • mrkmpn
            Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
            by mrkmpn
            Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
            This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
            03-13-2024, 01:54 PM
          • pabloroggeri
            Lenovo V310-15ISK - It doesn't work after changing the battery
            by pabloroggeri
            Good guys. I changed the battery to a Lenovo V310-15ISK.
            The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
            When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
            08-23-2024, 12:01 PM
