Packard Bell Easy note TV power problem
  • claudyu07
    Claudyu07
    • May 2014
    • 125
    • Ireland
    hi guys
    i have a Packard Bell Easy note TV here with power problem.
    Switch on , power light on , fan spinning and black screen , shut down after few seconds.
    same story over and over , keep shutting down after few seconds and no video
    Motherboard LA-8331P Q5WV8
    Any ideas ?
  • claudyu07
    Claudyu07
    • May 2014
    • 125
    • Ireland
    Re: Packard Bell Easy note TV power problem
    Have schematics but looking for bios file to try to flash it if anyone have. AMD processor.
    • claudyu07
      Claudyu07
      • May 2014
      • 125
      • Ireland
      anyone pls?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        backup old bios and try this
        Im Back... sort of...
        • claudyu07
          Claudyu07
          • May 2014
          • 125
          • Ireland
          thanks. will post back in few
          • claudyu07
            Claudyu07
            • May 2014
            • 125
            • Ireland
            Still same problem . Just noticed , when connect power supply and press power , fan spinning lights on, black screen and shut down after few seconds .
            If i press again the power button , same story but fan is not spinning anymore.
            if disconnect power supply and reconnect , again is spinning first time.
            Any ideas?
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              90% vga or chipset problem... try to reflow or reball
              • claudyu07
                Claudyu07
                • May 2014
                • 125
                • Ireland
                reflow fixed , will reball it now . thanks
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  no problem. bad ati can do all kind of weird symptoms
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Duranitron
                    Asus x512dk rev 2.1 power on problem
                    by Duranitron
                    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                    11-26-2024, 10:22 PM
                    Packard Bell Easy Note EN TE11BZ Q5WT6 Laptop Schematic
                    LA-8531P Rev 0.3...
                    11-06-2024, 06:29 AM
                  • EazyBone
                    LG OLED55C9PUA power problem
                    by EazyBone
                    Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                    Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                    I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                    The power supply to t con is different story.
                    This...
                    06-23-2023, 07:43 AM
                  • Dr.d
                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                    by Dr.d
                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                    04-05-2024, 11:48 AM
