Logic board repair help needed A1229 17"
  • lcdcaps1
    • Oct 2011
    • 322
    Hi
    All
    I hope everyone is well
    I am in need for some help. I have a 17" Macbook pro that was working very well untill a few days ago.
    It went idle and when I went back to wake it up it did not.
    I removed the charger and battery and kepted the power button pressed
    When i go to turn it on, I hear the hard drive spin and get a solid white light in the front on the latch button but doesnt display video,
    I have been doing allot of reading and people are suggesting its a video issue.
    I have done a reflow no change.
    I read some where on the forums some one said touch the "SYS RST" PADS to reset but I did this no reaction. I have tried bypassing the SMC but no louck.
    I started measuring voltages and inspecting the logic board for problems but cannot find any
    I have managed to read the scematics for my macbook pro and started testing votage on some of the chips and I am getting the right voltage according to the data sheets.
    If it was the common video problem then a reflow should have fixed it but I think something has failed but not sure. Please help
    I am hoping some one can help me to bring my mscbook pro by back to life.
    If I need to replace a component then that will be no issue,
    I look forward to the responses.
    Attached is the schematic that I found online
    Many Thanks
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Logic board repair help needed A1229 17"
    after a pram reset, do you hear a chime sound ?
    • lcdcaps1
      • Oct 2011
      • 322
      I forgot to add that the charger light is green and the battery charges
      the laptop turns on from the battery as well
      I am not sure but maybe a chip has gone or diode or something
      Please help
      • m4a2t0t
        • Mar 2013
        • 279
        Reflow or Heatgun? A reflow isn't the best for testing because it doesn't always work. I have reflowed systems and they still had the same issue but right after a reball it was fixed.
        Does your macbook have an external video output?
        Do you hear the chime or any sounds at any time?
        • lcdcaps1
          • Oct 2011
          • 322
          When I do the PRAM on the leyboard no reaction
          and no reaction when I touch the SYS RST pads on the logic board
          I reflowed with the hot air station not heat gun
          I have not got the hardware to do a reball maybe something to invest in later but not now
          • lcdcaps1
            • Oct 2011
            • 322
            no chimes or beeps
            whats strange is that before if no ram was present the front white light would flash
            that doesnt happen any more
            neither does it beep
            • lcdcaps1
              • Oct 2011
              • 322
              Can any one help
              Maybe its a fuse
              Are there arming measurements I can do.
              • lcdcaps1
                • Oct 2011
                • 322
                Sorry typo
                Are there any measurements I can do
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Yanleb
                  LG 60PK550 Logic Control Board EBR63450301
                  by Yanleb
                  Hi all, I just want to share the repair of my 60PK550-UA TV set.
                  The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                  But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                  All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                  C57: 3.30V
                  C61:...
                  07-20-2023, 12:38 AM
                • boosti45
                  MacBook logic board 820–01949 repair help needed please
                  by boosti45
                  I have a 2020 MacBook Pro touch bar 13 inch with the board 820–01949 that I'm currently working on that is my personal computer and long story short quit working got 5 V and no amps found out the computer was in DFU mode and I finally got it to go through and get on, and it would make it about halfway through, and then it would freeze while reviving so I would end up turning it off and starting over and on the third or fourth attempt I decided just to let it sit there and be frozen and see if it eventually finished and I came back like 15 minutes later and the computer was off and so I ended...
                  09-12-2024, 12:32 AM
                • korben_dallas
                  Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                  by korben_dallas
                  Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                  I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                  I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                  MY QUESTION:
                  I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                  02-14-2024, 12:23 AM
