Dell N5010 not charging
  • quic307
    • Jun 2015
    • 255
    • Greece
    I have a problem with charging, the laptop works but cannot recognize the power adapter and cannot charge the battery. I found the problem with the DG15 io Board (48.4hh02.001), any help? Maybe the problem is in dc jack?
    I use another battery and charger, the problem remains.
    Thanks ...
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Dell N5010 not charging
    Not recognizing adapter has to do with EC controller. If you have already tried a different adaptor and you have access to an oscilloscope check for data signal on pin 100 of EC (U3701) controller.
    • quic307
      • Jun 2015
      • 255
      • Greece
      I just found another DG15 io Board and it works.
      One mosfet is the problem, and I cant see what is it...
      Has anyone the schematis of 48.4hh02.001?
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        https://www.badcaps.net/forum/showpo...29&postcount=1
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          Originally posted by quic307
          Has anyone the schematis?
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Thomasraud
            Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
            by Thomasraud
            i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
            QUOTED
            -It works on charger (without battery connected-only charger)
            -It works on battery (without charger connected-only battery)
            -& it also works when plugged in battery & charger, but it's not charging the battery
            //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
            and..
            QUOTE
            The IC cannot maintain the input current level
            06-28-2022, 06:47 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • Grucha98
            Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
            by Grucha98
            Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
            Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
            09-09-2024, 11:22 AM
