is it possible to get motherboard part number in Windows?
Motherboard part number
Re: Motherboard part number
Use software like Aida64 , it will tell you detailed information about every component in the PC.
Aida64: http://www.aida64.com/downloads -
by manosjkhHello everyone.
In the attached photo of this Huawei motherboard I would appreciate if anyone of you knows the type of the IC in the red circle.
Thank you very much in advance.
by esiniorHi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
I've attached pics of this part
Thanks...4 Photos -
by YanlebIn the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
For an example, look at the attached PDF.
Do you have a way to cross reference the Panasonic part number with the actual part number?
Thanks....07-03-2023, 08:16 PM -
by Friend33Hello,
I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at... -
by KiajalaliHello everyone! I'm encountering difficulties with this motherboard. There are some components that doesn't show any voltage reading, however, it reacts to power button and it's consuming .178-198 amperes. Any help would be appreciated!
Channel: Schematic Requests ONLY!
06-08-2023, 05:34 PM -
- Loading...
