acer v5-531 no power need some help guys..
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello everyone. hope u could help
    i got this laptop no power
    i found out there is shorted line goes to charging IC PU4003.
    pin 1 2 is shorted to ground.
    pls see attach file for more info tnx.
    i found mosfets PU4001 and PU4002 that gets hot upon pluging ac adapter.
    try to remove and test but it still shorted line.
    try to check some caps along the line remove and test but it still shorted line
    tried to removed PR4004 between line of mosfet PU4001 and PU4002
    and i got shorted line gone from PU4001 to PR4001 but PU4002 to Pr4001 is still shorted.
    tried to trace shorted parts on PU4002 line. no luck everything remove from this line.
    any idea guys tnx.
  • dj_ricoh
    • 2073
    • uk
    Re: acer v5-531 no power need some help guys..
    Wtf is that kok& balz drawing?
    So. Short right side on BT+.
    What pins are short if you lift pu4002?
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      Get your self a bench power supply and see what gets hot and pc4005/pc4025/pc400 check for short .
      • rickybucalan
        • May 2013
        • 322
        • philippines
        yes that right BT+ is short..
        pin 123 is short even i lift pu4002
        • dj_ricoh
          • 2073
          • uk
          No. If only 1.2.3 shorted b+ its ok.
          Then its local near ic.
          All with green they are off right?
          Take out pd4003, pu4004 and pu4005(pin1,2,3 its connected to ground)
          • rickybucalan
            • May 2013
            • 322
            • philippines
            here is the diagram page 40..
            PU4004 only pin 5678 shorted to ground
            PU4005 only pin 123 shorted to ground
            • rickybucalan
              • May 2013
              • 322
              • philippines
              • rickybucalan
                • May 2013
                • 322
                • philippines
                • dj_ricoh
                  • 2073
                  • uk
                  Ok.
                  Short on pu4004.
                  From the fet pu4004 to dcbatout point you got 3 caps. Take them out if pads shorted we go further.
                  Post the diagram where is dcbatout coming from.
                  • Lee M.
                    IR night vision goggles to find shorted panel line?
                    by Lee M.
                    Has anybody tried to use IR night vision goggles or other thermal imaging device to find a shorted line in a ribbon cable going from a panel driver board into the panel? I would think the shorted line would get hotter than the other lines and might just show up on a thermal imaging device. Just wondering if anyone has tried this and if so did it work?
                    11-10-2023, 03:19 PM
                  • Yanleb
                    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                    by Yanleb
                    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                    D608, good
                    D618 RF101L4S, good (See warning 1 below)
                    D619 RF101L4S, good (See warning 1 below)
                    D865 RF101L4S, shorted (See warning 1 below)
                    IC464 Inverter HA MC74HC1G14, shorted...
                    03-09-2020, 12:00 AM
                  • kalilinux25
                    LENOVO Shorted +5VALW AND +3VALW LINE ACLU9/ACLU0 NM-A311
                    by kalilinux25
                    Hi good day to all hope someone can give me some advice whats happening to this board.
                    Ive check the output voltage line of +5valw and +3valw all shorted I thought I was having a SIO shorted to.
                    I try to remove the SIO chip But still shorted I tried to check all CAPS of the pu401 and PU402 all ok
                    SHORTED TO GROUND
                    PL402 AND PL401 , i tried also to remove the 2 coils and test the PJ402 and PJ406 im having short at those sections,
                    I hope someone can guide me if anyone, Thank You in advance...
                    01-20-2021, 11:56 PM
                  • Mousetohome
                    PS5 Shorted power button line
                    by Mousetohome
                    I been trying to trace this via for a few hours now, Could someone tell me what Chip gets Ground to power up the console? Or maybe about where it should go? This is from a EDM-033 but i would imagine most are the same....
                    09-21-2024, 01:43 PM
                  • modtool
                    HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                    by modtool
                    Hi to all,
                    the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                    I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                    I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                    04-01-2025, 08:22 AM
