Acer M5-481PT backlight issue
			by CornitoHello Team,
 I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
 Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
 Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
			by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
 Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
 Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
 The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
 Anyone...
			by CornitoHello team,
 I'm back with another topic.
 It's a 65C715 TCL tv with backlight issue.
 But the problem is a bit strange.
 When I took this tv from the marketplace backlight didn't work but picture was ok.
 Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
 Putting all back together the tv worked fine for weeks. => Contact issue??
 Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
			by MireniaHi everyone,
 got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
 The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
 If this happened once, then the laptop only runs for a few minutes until restart.
 This happens regardless while staying in windows or uefi or in a linux environment.
 At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
			by ahmarzoHave a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
 Help me to diagnose this issue as there is no shortage in the inputs MOSFET
- Loading...
