Samsung Np350v5c charging circuit problem
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Hi have samsung laptop which give me this problem .Turn on normal battery status charging but actually not charging at all,works both with battery or without battery ,NOW when u start laptop only with battery and then later connected adapter laptop dont recognize adapter and if u take battery laptop switch off BUT same scenario starting laptop with battery and later connected adapter and then uninstall in device manager Microsoft ACPI controll battery laptop start recognize adapter but not charging ,Try to solder new charging chip from another same motherboard still same symptoms ,new bios same thing ,different adapter same ,anyone have experience with that laptop and what I should measure on motherboard to get work(Draining power not work)
    Samsung Np350v5c
    Intel i5
    dual graphic with Intel and radeon 7700
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Re: Samsung Np350v5c charging circuit problem
    Anyone
    • DSpawnZ
      • May 2009
      • 20
      • Argentina
      Hi. I would start by checking at PU200, check ACDET and ACOK signal levels.
      Check how they change when you plug and unplug the charger.
      • ciki
        • Aug 2014
        • 132
        • Ireland
        Hi thx for helping I already change PU200 with another one and same thing ,I will try again to change the Bios or it here any mofset around PU200 that have something with adapter and battery or should I try to change power connection to matherboard
        • ciki
          • Aug 2014
          • 132
          • Ireland
          I cant locate the acdet chip PC245 or PR246 on motherboard
          • DSpawnZ
            • May 2009
            • 20
            • Argentina
            Sometimes they are hard to find, as one would think that they might be close each other, or close to a chip, and you turn out finding that they are on the opposite side of the board. This can be frustrating. Don't give up searching. Samsungs are particularly known for missing or totally missing component reference on the PCB.
            • ciki
              • Aug 2014
              • 132
              • Ireland
              Still nothing cant find
              • DSpawnZ
                • May 2009
                • 20
                • Argentina
                Tell me the board number. Usually starts with BAxxxxx, this might be on a sticker near the RAM slots, or printed on the board.
                • ciki
                  • Aug 2014
                  • 132
                  • Ireland
                  qcla4 la-8861p
                  rev 2.0
                  and sticker with qcla4 UH3 4M P02 A13A
                  BA59-03540A
                  • mohamed.mostafa
                    • Sep 2012
                    • 40
                    • egypt
                    did you solve it ? i have same problem with same board la-8861p .
                    • ecolaptop
                      SM-R180 Samsung Galaxy Buds Help Identifying component in charging circuit.
                      by ecolaptop
                      Hi.
                      Could anyone have some hart and pity to help me identify this transistor? I believe this is a transistor but who knows... .
                      When it was in I had no ground on charging pins of actual earbuds. When unsoldered ground came back and now it is charging itself, it is charging earbuds as well and that did not happen before.
                      When I test it it don't look like transistor but like double diode leg 2(middle - possibly emitter) to 1 and 2 to 3 connected showing 0.8 volt drop, in reverse it is open circuit and across 1 to 2 both directions it is open circuit.
                      Is this a double...
                      02-06-2023, 05:45 AM
                      09-07-2024, 05:50 AM
                    • repair-it
                      Engineering help - how does the charging circuit on this board work?
                      by repair-it
                      This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
                      08-31-2024, 12:32 PM
                    • fab13
                      Nintendo Switch lite charging chip heats up and does not short circuit
                      by fab13
                      Hello everyone
                      Small technical problem on a Nintendo Switch lite
                      Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
                      After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
                      When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
                      Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
                      09-16-2023, 04:59 AM
                      09-06-2024, 11:40 PM
