HP G62 ghostbusting
  • bbf
    • Aug 2015
    • Slovenia
    HP G62 ghostbusting
    Hello all!
    This is my first post here, hope I'll find some answers here
    Here is this situation: I friend hands me an G62 with dead USBs, card reader and audio - to check for power issues. But it turns out it is beyond my skills to pinpoint the exact problem.
    Exact motherboard type is 01013y000-575-g , I am using schem hp_g62_compaq_cq62_foxconn_star_federer_rev_1.0_sch.pdf, it is not 100% correct, but it is OK for me (so far the difference found was only at PQ561).
    OS check: I did check different OSes to rule out any driver issues:
    win7 Enterprise
    -Camera not present in dev manager
    -Sound card (High definition Audio Controller) : Code 10 in dev manager
    -card reader not present (no function) in dev manager
    -LAN adapter not present in dev manager
    -EXT.USB 0,1,2 no function, no data transfer, +5V OK!
    Ubuntu 13.10 live :
    -no sound hardware found
    -USB no function
    Ubuntu 14.04.2 i386 32bit live :
    -no sound hardware found-
    -USB no function
    Blutooth hardware is not installed, so I can't check it's USB communication.
    working (tested on win7):
    WLAN OK - this might use USB port 11, or else just PCIe
    Synaptics OK
    VGA OK
    SATA 1 2 OK
    charging OK
    keyboard OK
    Some masuring on MB was made to check power issues - checked at power on, at naked motherboard on battery, no other hardware connected:
    USBRBIAS RS93 : OK
    PCH POWER voltages @ CS28, CS35, CS38, DS4, CS39 : OK
    voltages around UB1 : OK
    data lines from con8 to LB1 pin 4 and pin 1 : OK
    Voltages on UC1 (card reader) Pin 8, 11 : OK ; pin 9 :no effect on card insert, always 0V
    Then there are this two peripherals, which use different ports than Ibexpeak USBs and are also unresponsible:
    LAN adapter uses PCIE and is also dead.
    Audio also isn't working, voltages are OK.
    USB data lines are 0V from cold. When inserting any known good USB flashdrive into one of the ports, 5V stays OK, one data line lifts to 3.04V and that's it. I didn't scope it though, thumb drive gives no activity with it's LED.
    Also cmos was reset with battery disconnection, confirmed via loss of RTC and
    downgraded from F.48 to F.35, made no difference.. Battery or charger - no difference.
    Board was mechanicaly stressed to check for intermittent behavior, made some pressing over and under Ibexpeak, all without success.
    What am I facing here? Something blocking clock? Ibexpeak half-dead? Corrupt firmware?
    Thanks for your time!
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: HP G62 ghostbusting
    Look for a short in a USB port, like bent/broken pins.
    • bbf
      • Aug 2015
      • Slovenia
      No visual damage at all, measuring yields protection diodes from dataline to GND in both directions; no shorts in between any pins or towards power lines. All 3 EXT USB ports measures the same.
      • Naveed Ahmed
        • Aug 2015
        • pakistan
        usb port damage 70% chance
        • Capacitorial
          Powersupply has all the voltages - Monitor still no power
          by Capacitorial
          Hello guys,
          I have a Philips 240B7QPJEB. The monitor seems completely dead.
          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
          The weird thing is, that the Power LED is powered over the TCON board.
          On The TCON...
          12-28-2024, 02:12 PM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
          Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
          This is a new item at Electronic GoldMine that has arrived within the last few weeks
          Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
          Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
          https://theelectronicgoldmine.com/products/g28392
          One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
          11-24-2024, 01:25 AM
        • gjgib
          Help reading schematic voltages input/output
          by gjgib
          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
          05-06-2024, 08:11 PM
        • RossMoodley1967
          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
          by RossMoodley1967
          Hello
          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
          03-01-2024, 06:07 AM
