Asus x551ca no power
  • puscas1983
    • Nov 2013
    • România
    i have a dead asus x551ca that won't power on.
    i checked the charger, power jack and all are ok.
    i have 19 v on the main route.
    little help with a scheme for the mainboard?
    thanks in advance
  • c_hegge
    • Sep 2009
    • 5219
    Re: Asus x551ca no power
    Moved to laptop troubleshooting. The Abit/ASUS/AOpen forum specifically covers desktop boards with bad caps.
    • Life Goes On
      • May 2014
      • 264
      • Curacao
      Try to flash the bios, you gone need a new dump.
      The Night Drop Down, I Will Keep Try Until..., You Never know.
      Dushi Kòrsou, Nos Tei.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
