asus x5dc no power
  • azza1234
    • Nov 2013
    • 124
    • united kingdom
    asus x5dc no power
    A family member gave me this laptop to see if I could repair it
    I've plugged in the ac adapter and there's a charging light that comes on but when I press the power button nothing happens I've tried reseating the ram and disconnecting the battery and adaptor holding down the power button and still nothing does anyone have a repair manual or any ideas how to fix the problem? Many thanks
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: asus x5dc no power
    You can try to flash the bios chip with a programmer.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • dj_ricoh
      • 2073
      • uk
      look for liquid residue.
      i just repair a similar(not exact model) asus.
      i found liquid residue on KBC, CPU power rail and 3.3v rail.
      Tough nothing was broken after cleaning i had to reflow (make new solder contacts)
      and everything was OK.
      • azza1234
        • Nov 2013
        • 124
        • united kingdom
        Hi there the motherboard is a k40c Does anybody have a schametic or repair manual or know where the BIOS chip is? Many thanks
        • azza1234
          • Nov 2013
          • 124
          • united kingdom
          Left the BIOS battery out overnight and its working again thanks everyone thou
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • ShadowAi
            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
            by ShadowAi
            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
            03-15-2024, 10:46 AM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
