Asus X550c - BQ24725A - low ACdrv signal
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Hello.
    Have this laptop Asus x550c that wont switch dcline mosfets because of low ACdrv signal/0.93V/. ACdet=3V,ACOK=3V,VCC=19V. Looks like ic's/BQ24725A/ charger pump for ACdrv is broken but i change it and looks the same.
    How to get high acdrv signal?
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Asus X550c - BQ24725A - low ACdrv signal
    I think you should try to replace new mosfet for AC_FET and BAT_FET
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3590
      • slovakia
      i remove acfet and test it. it is good
      i read in datasheet that Vacdrv=Vcmsrc+6V but i have Vcmsrc=0.93V
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        yes if you have the test results are not short, but in my opinion, gate charge problematic. maybe...
        • saularciga
          • Feb 2014
          • 55
          • mexico
          posted diagram please
          • saularciga
            • Feb 2014
            • 55
            • mexico
            Is true , In the gate should have 19 vcc + 6V
            • saularciga
              • Feb 2014
              • 55
              • mexico
              Check the capacitor near area of mosfets
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                Hello.
                acdet a little high, i think must be arround 2.6v so check resistor first
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3590
                  • slovakia
                  acdet must be 2.4-3.15v
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    replace mosfet as metitosari said . they might seem good if you check, but can have gate issue
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3590
                      • slovakia
                      what is "gate issue", i test it with multimeter and works fine
                      • Esse
                        • Apr 2014
                        • 317
                        • TOGO
                        dycc,what is it the gate issue
                        • whaldsz
                          • Apr 2013
                          • 395
                          • Philippines
                          Could you check the resistance to GROUND of ACDRV and CMSRC pin?
